paun nelu Posted September 8, 2010 Share Posted September 8, 2010 acest tv a fost traznit - sa rezolvat dar nu am sunet ,am pus o alta mem, i-am dat opt. de pe tub si tot nu am sunet!nu mai am nici o idee,help! Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted September 8, 2010 Share Posted September 8, 2010 Salut ! dar integratul de sunet este bun,l-ati verificat daca este bun sau rau? Link to comment Share on other sites More sharing options...
paun nelu Posted September 8, 2010 Author Share Posted September 8, 2010 Salut ! dar integratul de sunet este bun,l-ati verificat daca este bun sau rau? imi e jena sa raspund la intrebare,cum naiba sa nu fie bun ! Link to comment Share on other sites More sharing options...
GYON Posted September 8, 2010 Share Posted September 8, 2010 Incercati sa delimitati defectul:la iesirea TDA este semnal AF sau actioneaza muting-ul asupra final sunet???Daca pe pinul 48 al TDA nu aveti semnal AF atunci aveti toate sansele ca TDA sa fie defect !Pe acest pin trbuie sa aveti 3,5v !!PS. Este cu MSP ???? Link to comment Share on other sites More sharing options...
Guest radu28 Posted September 8, 2010 Share Posted September 8, 2010 Nu va luati dupa optiunile de pe tub.Vedeti DEPANATORUL Nr. 28. La sasiul L01.1 varianta verificata este:OB1:220,OB2:246,OB3:65,OB4:16,OB5:208,OB6:54,OB7:65. bafta! Link to comment Share on other sites More sharing options...
paun nelu Posted September 9, 2010 Author Share Posted September 9, 2010 Nu va luati dupa optiunile de pe tub.Vedeti DEPANATORUL Nr. 28. La sasiul L01.1 varianta verificata este:OB1:220,OB2:246,OB3:65,OB4:16,OB5:208,OB6:54,OB7:65. bafta!Am schimbat opt. si tot degeaba,mai are cineva vre-o idee? Link to comment Share on other sites More sharing options...
bobo Posted September 9, 2010 Share Posted September 9, 2010 ati verificat ce spune gyon?este perfect adevarat. Link to comment Share on other sites More sharing options...
paun nelu Posted September 9, 2010 Author Share Posted September 9, 2010 Incercati sa delimitati defectul:la iesirea TDA este semnal AF sau actioneaza muting-ul asupra final sunet???Daca pe pinul 48 al TDA nu aveti semnal AF atunci aveti toate sansele ca TDA sa fie defect !Pe acest pin trbuie sa aveti 3,5v !!PS. Este cu MSP ????este cu msp 3415g , nu am semnal af dupa el;se poate inlocui cu msp3400? Link to comment Share on other sites More sharing options...
daisarqx Posted September 9, 2010 Share Posted September 9, 2010 sda, scl ajung la msp? Link to comment Share on other sites More sharing options...
naebv Posted September 10, 2010 Share Posted September 10, 2010 MSP3415G nu poate se poate inlocui MSP3400. Link to comment Share on other sites More sharing options...
Archived
