mercenarx Posted September 1, 2010 Share Posted September 1, 2010 salutare !am la reparat un tv BLUESKY sasiu 11ak36 cu urmatoarea problema -ul a fost traznit, i-am gasit arsa sursa si...cam toti-am pus sursa in functiune (pe bec) , schimbat proc ST... , jungla STV... , si tv-ul prezinta acum urm simptom :apasand intrerupator general , ledul se aprinde rosu ; actionand p+ led-ul se face verde pt o secunda , apoi trece in rosu la loc .in timpul cat led-ul e verde , masurand cu osciloscopul, NU am impulsuri in baza bu 808idei? Link to comment Share on other sites More sharing options...
tiby_1981 Posted September 1, 2010 Share Posted September 1, 2010 Memoria?Tensiunea de pe u1? Link to comment Share on other sites More sharing options...
Alenicand Posted September 1, 2010 Share Posted September 1, 2010 daca a fost trasnit poate fi orice verifica protectii, informatii... Link to comment Share on other sites More sharing options...
mercenarx Posted September 1, 2010 Author Share Posted September 1, 2010 care-s conditiile de baza ca sa plece liniile la acest sasiu ? Link to comment Share on other sites More sharing options...
mercenarx Posted September 1, 2010 Author Share Posted September 1, 2010 care-s conditiile de baza ca sa plece liniile la acest sasiu ?imi raspund singur una din conditii este prezenta tensiunii de 5v in pin 12 la STV2247 (initial fusese STV2248), ceea ce in cazul meu lipsea (o intrerupere pe placa)acum insa am alta problema -ul functioneaza perfect, insa se incalzeste foarte tare STV 2247; care poate fi cauza ?are cineva idee? Link to comment Share on other sites More sharing options...
naebv Posted September 1, 2010 Share Posted September 1, 2010 Cat de tare se incalzeste? O temperatura la nivelul extern al capsulei =...? Link to comment Share on other sites More sharing options...
palcu ion Posted September 1, 2010 Share Posted September 1, 2010 oricum merge incins,dar daca nu pateste nimic 3-4 ore e ok Link to comment Share on other sites More sharing options...
mercenarx Posted September 1, 2010 Author Share Posted September 1, 2010 oricum merge incins,dar daca nu pateste nimic 3-4 ore e okdl palcu ion are dreptate, asa functioneaza stv2247(48)h, la temperatura mai mare , intrucat a stat la "ars" toata ziua . daca era ceva in neregula , crapa pana acum..oricum tv-ul asta e pus sa ma enerveze rau, deoarece acum are o anumita pozitie (cu placa putin torsionata ) in care nu se mai vede imaginea, se aude doar sonorul si OSD ; imaginea este vizibila doar cu lumina stinsa si foarte, foarte intunecata; ziua ai zice ca e opritdaca ati avea o idee sa termin cu el mai repede ars fi recunoscator, fiindca l-am pus si dat jos de pe masa de N'spe mii de ori(imaginea vine si pleaca brusc, deci exclus filament)chiar m-a plictisitla buna vedere ! Link to comment Share on other sites More sharing options...
mercenarx Posted September 2, 2010 Author Share Posted September 2, 2010 rezolvat : tot o intrerupere pe placa (nu ajungeau 8v pe colector Q101 sau Q102 , nu m-am mai uitat cu atentie , fiindca mi s-a luat de tv-ul asta) Link to comment Share on other sites More sharing options...
palcu ion Posted September 2, 2010 Share Posted September 2, 2010 daca se insista atunci sansele da reusita sunt maxime Link to comment Share on other sites More sharing options...
mercenarx Posted September 2, 2010 Author Share Posted September 2, 2010 daca se insista atunci sansele da reusita sunt maxime dar cateodata , parca iti vine sa le lasi in ...BEEEEP..ma-si de aparate ca unele au niste defecte de te apuca stenahoria ..unde mai pui, cateodata vin si cu suveniruri (a se citi "defecte") de pe la altii...cateodata rezolvi patru intr-o zi , alta data unu in patru zile (bine ca prima varianta e mai frecventa , ca altfel..)si, colac peste pupaza , mai dai de cate unu" care zice ca "ce i-ai facut ca nu i-ai schimbat decat o piesa de 5 lei..."defecte rezolvabile rapid la toata lumea ! Link to comment Share on other sites More sharing options...
palcu ion Posted September 2, 2010 Share Posted September 2, 2010 un amic avea o vorba:"daca-i ceri 5 lei iti vorbeste la"per tu",daca-i ceri 50 iti zice *domnu" inginer,in ziua de azi trebuie sa combinam astfel ca sa fie toata lumea multumita,ideea e ca nu trebuie sa stea clientul langa tine,iar daca sta si are replici ca aceea"ce i-ai facut ca nu i-ai schimbat decat o piesa de 5 lei " trebuie sa i spui chestia cu ciocanul:un sofer a ramas in pana si cateva ore nu l-a rezolvat nimeni....vine cineva si -i spune:"da-mi un ciocan",acesta ii da si dupa doua lovituri in cutare loc porneste masina!Cat ma costa?intreaba omul bucuroso suta de mii!cum,asa mult?o mie ciocanul si 99 de mii ca am stiut unde sa dau cu el!!!!!!meseria asta e delicata,de aia multi incearca sa faca ce facem noi si de multe ori mai mult ne dau de lucru,dar si asta e un lucru bun pana la urma Link to comment Share on other sites More sharing options...
mercenarx Posted September 2, 2010 Author Share Posted September 2, 2010 un amic avea o vorba:"daca-i ceri 5 lei iti vorbeste la"per tu",daca-i ceri 50 iti zice *domnu" inginer,in ziua de azi trebuie sa combinam astfel ca sa fie toata lumea multumita,ideea e ca nu trebuie sa stea clientul langa tine,iar daca sta si are replici ca aceea"ce i-ai facut ca nu i-ai schimbat decat o piesa de 5 lei " trebuie sa i spui chestia cu ciocanul: un sofer a ramas in pana si cateva ore nu l-a rezolvat nimeni....vine cineva si -i spune:"da-mi un ciocan",acesta ii da si dupa doua lovituri in cutare loc porneste masina!Cat ma costa?intreaba omul bucuros o suta de mii! cum,asa mult? o mie ciocanul si 99 de mii ca am stiut unde sa dau cu el!!!!!! meseria asta e delicata,de aia multi incearca sa faca ce facem noi si de multe ori mai mult ne dau de lucru,dar si asta e un lucru bun pana la urma nu pot decat sa fiu de acord . in bransa asta se aplica sintagma :"ieftinul mai mult pagubeste". dar , ma rog , cum ziceai ,: daca asa vrea el ?... numai bine ! Link to comment Share on other sites More sharing options...
Archived
