Guest mrdjcoco15 Posted August 30, 2010 Share Posted August 30, 2010 salutare. am un amplificator behringer ep 2500 si as dorii sa achizitionez niste boxe si nu stiu ce sa iau. bugetul ar fii cam 1000ron /boxa.astept niste pareri .m-am uitat putin la Peavey PV 215 .ce ziceti?multumesc Link to comment Share on other sites More sharing options...
stefanstudio Posted August 30, 2010 Share Posted August 30, 2010 daca ne dai si niste detalii tehnice despre amplificator poate poate Link to comment Share on other sites More sharing options...
Guest mrdjcoco15 Posted August 30, 2010 Share Posted August 30, 2010 Amplificator audio 2 x 750 W la 4 Ohmi dotat cu transformator toroidal cu nivel foarte scazut de interferenta si cu sistem de ventilare foarte eficient. Putere (1kHz @ 0.1% THD): 2 x 750 W la 4 Ohmi; 2 x 500 W la 8 Ohmi; 2 x 1200 W la 2 OhmiPutere punte mono: 1 x 1500 W la 8 Ohmi; 1 x 2400 W la 4 Ohmi. Conectori intrare: XLR si TRS (jack 1/4") balansate. Conectori iesire: borne si Neutrik Speakon. Dimensiuni (I x L x A): 88 (2U rack) x 482.6 x 402 mm. Greutate: 16.6 kg Link to comment Share on other sites More sharing options...
Guest danyelM Posted September 2, 2010 Share Posted September 2, 2010 pv 215 am si eu:P legate la un bluetech MA-600, si iti spun sincer ca se aud super frumos, si eu am stat mult pana m am hotarat c boxe sa iau. Link to comment Share on other sites More sharing options...
Guest mrdjcoco15 Posted September 7, 2010 Share Posted September 7, 2010 deci as putea sa le folosesc fara nici o problema la ep2500.??? Link to comment Share on other sites More sharing options...
Guest danyelM Posted September 7, 2010 Share Posted September 7, 2010 le poti folosii fara nici o problema dar nu cu ampliful in max, ele sunt pe 4 ohm si are 350W rms in 4 ohm si 700W in 4 ohm program, iar ampliful tau are 500w in 4ohm, trebuie doar sa ai grija de ele, in rest functioneaza perfect si se aud chiar foarte tare Link to comment Share on other sites More sharing options...
Archived
