Jump to content
ivanflorin
MENIU SERVICE PLATINIUM
Menu service: Se apasa de doua ori tasta MENU-apare PICTURE MENU .Se apasa tasta Q.VIEW sau RETURN ,apoi se apasa tasta MUTE. Trecerea la pagina urmatoare--tasta TIMER(SLEEP) . Iesire cu tasta MENU. :da Vedeti si dvs daca merge cu varianta asta,daca nu merge sa ne spuneti ce procesor are tv-ul. :101 Asteptam raspunsul. :dans: Succes ! :aplauze
Link to comment
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
