Jump to content
dump blaupunkt PM51-43vt
  • Replies 2
  • Created
  • Last Reply
Top Posters In This Topic
salut! am o problema cu un tv,Blaupunkt dupa un trasnet sa blocat pe cild look,si acum imi cere cod.rog pe cineva care poate sa ma ajute cu un damp. :jytuiyu
Daca e blocat pe cild look ,pardon, child lock,poti sa-l deblochezi fara dump.Apesi de pe telecomanda VOL+;VOL-;P- urmat de P+.
Blaupunkt PM51-43 VT = chassis FM 241.00 = Grundig CUC6300
Link to comment
Join the conversation
Guest
Unfortunately, your content contains terms that we do not allow. Please edit your content to remove the highlighted words below.
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
  • Create New...
Important Information
