Jump to content
smd-man
Placa CV075GST_V3
La monitorul LCD ce are si tuner tv SCOTT TVX5 ce contine : Placa = CV075GST_V3SELECTOR = TSN3311-Q * U2 = 9435 SC * U5 = ATMEL630 24C16AN * U7 = AZ1084S2 -3,3EI * U9 = SC 7313 S * U1 = TDA1517P * U4 = 9435 SC * U16 = FM24C02 * U12 = BM1117 – 2,5 * U13 = ACT4060 SH * U14 = HCF4052 * U10 = MST718BE-LF s-a prajit procesorul (MST718BE-LF). Scurt pe bara de 5 volti. Aveti idee daca pot gasi acest procesor? Sau daca are cineva de pe forum de vanzare aceasta placa. Dupa sapaturi pe net am aflat ca acceiasi placa se afla si in urmatoarele monitoare LCD: TRONY1502 , BRAUNLC15/HK-06RS , SAMSUNG 14” CHINA , AKAI LTA-15E307 . Atasez si o poza cu placa. Astept idei.
Link to comment
Share on other sites
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
Important Information
