Jump to content
Royal TV3788 TXT probleme pornire
Buna ziua!Am acest tv care face figuri la pornire si anume ca ledul de st-by cateodata se aprinde si cateodata are tendinta de a se aprinde doar ca face sursa un fel de "carait".daca apuca sa porneasca ledul atunci dau drumul si tv merge,mentionez ca am schimbat cele 3 electrolitici de 100uf/50V din primarul sursei.Eventual o schema daca se poate mi-ar prinde bine.Ce poate cauza acest defect?Va multumesc.
Link to comment
  • Replies 3
  • Created
  • Last Reply
Top Posters In This Topic
Popular Days
Join the conversation
Guest
Unfortunately, your content contains terms that we do not allow. Please edit your content to remove the highlighted words below.
Reply to this topic...
×   Pasted as rich text.   Restore formatting
  Only 75 emoji are allowed.
  • Create New...
Important Information
