florinellll Posted June 20, 2010 Share Posted June 20, 2010 Va salut.Daca ma puteti ajuta cu un dump pentru tv Provision Model 2822tSasiu 40-MNTV4KS-L4W.Procesor ST92195C7B1/MLEJungla STV8216Memorie 24c08Multumesc Link to comment Share on other sites More sharing options...
elmar Posted June 20, 2010 Share Posted June 20, 2010 Icercati pe acesta:Chassis: TV4K CHASSIS TVProcessor: ST92195C7B1 MLE FORESEE WXMemory: 24C08 Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted June 20, 2010 Share Posted June 20, 2010 Va Salut incercati cu damp-urile asta,pt ca este pt procesorul ST92195C7B1/MLE si memoria 24C08 . Succes !!! Link to comment Share on other sites More sharing options...
florinellll Posted June 20, 2010 Author Share Posted June 20, 2010 Mersi elmar ,cred ca am probleme cu procesorul.Are rastru cu "pureci" nu afiseaza OSD nu functioneaza nici un buton de pe panoul frontal.Am incercat diferite dump-uri aceiasi manifestare.Mai sap in jurul procesorului.Voi ce ideii imi dati? Link to comment Share on other sites More sharing options...
elmar Posted June 20, 2010 Share Posted June 20, 2010 Verificati v-sinc si h-sinc care ajunge la procesor in pinii 40 si 41...si masurati sa vedeti daca aveti tensiunea de 5v care are legatura cu aceste semnale(de sincronizare) ,tastatura tv si receptorul IR. Link to comment Share on other sites More sharing options...
florinellll Posted June 20, 2010 Author Share Posted June 20, 2010 Tensiunile sunt: pin 40 ,0.58v;pin 41 ,4.08v.In legatura cu butoanele m-am exprimat gresit ,cand il conectez la retea intra in standby apas P+sau P_ tv porneste insa dupa aceia nu mai functioneaza butoanele.Daca m-ati putea ajuta cu o schema.Multumesc Link to comment Share on other sites More sharing options...
elmar Posted June 20, 2010 Share Posted June 20, 2010 schema,sper sa va ajute sa rezolvati defectul... Link to comment Share on other sites More sharing options...
florinellll Posted June 25, 2010 Author Share Posted June 25, 2010 S-a rezolvat .Mersi elmar Link to comment Share on other sites More sharing options...
dan-a2 Posted June 25, 2010 Share Posted June 25, 2010 spune si cum l-ai rezolvat ! Link to comment Share on other sites More sharing options...
costi75 Posted November 14, 2010 Share Posted November 14, 2010 Salut. Am si eu aceeasi problema cu un sasiu usor diferit.Est vorba de 40-MNTV4KS 1,5W pe un TV Sinudyne 2930A Flat.La actionarea butonului de retea sursa intra in standby si porneste la actionarea butoanelor P+ sau P- .Nu am OSD,nu mai functioneaza butoanele de pe panoul frontal iar imaginea(cu rastru) nu se desfasoara total pe verticala(cam jumatate).Tensiunile in sursa sunt OK.Ma poate ajuta cineva cu un sfat? Multumesc. Link to comment Share on other sites More sharing options...
Guest meganet Posted November 14, 2010 Share Posted November 14, 2010 ne spui si cum ai rezolvat problema ?dump provision model 2822t,te rog? Link to comment Share on other sites More sharing options...
Guest meganet Posted November 14, 2010 Share Posted November 14, 2010 buna,elmar ,te rog ajuta-ma cu schema tv provision 2822t ,procesor st92195cb1dar cu jungla stv82162204 fvp.multumesc frumos Link to comment Share on other sites More sharing options...
elmar Posted November 14, 2010 Share Posted November 14, 2010 Sunteti sigur ca nu este schema atasata de mine mai sus? Link to comment Share on other sites More sharing options...
Guest meganet Posted November 16, 2010 Share Posted November 16, 2010 sunt sigura.schema oferita de tine ,are jungla stv 2246/2248.am tv cu toate caracteristicile mentionate de florinell ,si cu acelasi defect.ma poti ajuta? Link to comment Share on other sites More sharing options...
elmar Posted November 16, 2010 Share Posted November 16, 2010 buna,elmar ,te rog ajuta-ma cu schema tv provision 2822t ,procesor st92195cb1dar cu jungla stv82162204 fvp.multumesc frumos Imi pare rau dar eu nu cunosc acest circuit (mai ales ca jungla) poate vreti sa spuneti asa cum a mentionat si Dl.Florinellll ...stv8216 dar este procesor audio si nu jungla...(cred ca din greseala a fost numit acolo jungla...) Link to comment Share on other sites More sharing options...
Archived
