Guest andreis Posted June 10, 2010 Share Posted June 10, 2010 Adica asta de aici: http://www.numark.com/dm1050 Au ajuns ceva lichide pe el, si acum pe iesirea de master am brum, iar uneori se aude un post de radio; nu conteaza daca e pornit sau oprit. Brumul se diminueaza daca opresc calculatorul (sunt in aceiasi priza, dar e la fel si daca mut prizele). Am verificat cabluri, le-am schimbat. sunt ok. Pe iesirea de record (sau cea de casti) nu face. Din pacate, schema n-am gasit-o. Link to comment Share on other sites More sharing options...
manely Posted June 10, 2010 Share Posted June 10, 2010 Cand opresti calculatorul e ca si cum ii scoti semnalu de intrare si dasta nu se mai aude, nu are nicio treaba ca este bagat in aceeasi priza cu PC'u. Link to comment Share on other sites More sharing options...
Guest andreis Posted June 10, 2010 Share Posted June 10, 2010 Aaa, nu. Brumul e la fel de mare si cu intrarea scoasa. Link to comment Share on other sites More sharing options...
manely Posted June 10, 2010 Share Posted June 10, 2010 L-ai desfacut? Ai uscat cu feonul? Link to comment Share on other sites More sharing options...
Guest andreis Posted June 10, 2010 Share Posted June 10, 2010 L-am desfacut, dar nu l-am uscat, trecusera 24h. (cantitatea de lichid n-a fost mare..) Incerc si o sa revin. Link to comment Share on other sites More sharing options...
Guest andreis Posted June 12, 2010 Share Posted June 12, 2010 Am gasit cablul care l-am folosit ultima data si se pare ca una din mufe era in scurt.\Deci, ce s-ar fi putut duce din partea de iesire in situatia asta? Link to comment Share on other sites More sharing options...
Archived
