bubusmecherul Posted April 23, 2010 Share Posted April 23, 2010 AM LA REPARAT UN TV LG MODEL CF-20D26X,care se manifesta asa;a fost ars final lini- care lam inlocuit si dupa ce lam inlocuit sa ars din nou finalul lini,am schimbat si condesatori care erau umflati,si am mai pus unul si iarasi sa ars.CINE ARE UN RASPUNS,ce o mai avea Link to comment Share on other sites More sharing options...
paun nelu Posted April 23, 2010 Share Posted April 23, 2010 daca ai avut cond. umflati verifica sursa Link to comment Share on other sites More sharing options...
bubusmecherul Posted April 23, 2010 Author Share Posted April 23, 2010 am verificat sursa pare an regula Link to comment Share on other sites More sharing options...
tehtronics Posted April 23, 2010 Share Posted April 23, 2010 adica...ce tensiuni scoate pe sarcina artificiala? Link to comment Share on other sites More sharing options...
bubusmecherul Posted April 23, 2010 Author Share Posted April 23, 2010 stie cineva va rog,am ars 3 bucati final lini ce dumnezeu are Link to comment Share on other sites More sharing options...
Nonny149 Posted April 23, 2010 Share Posted April 23, 2010 Tensiune de alimentare mare ,traf de linii defect ,bobina de deflexie cu scurtcircuit intr spire,condensator din colector final linii defect.Tu trebuie sa identifici cauza. Link to comment Share on other sites More sharing options...
bubusmecherul Posted April 23, 2010 Author Share Posted April 23, 2010 final lini C5250-7D1 ars- cu ce final lini sar mai potrivi Link to comment Share on other sites More sharing options...
Alenicand Posted April 23, 2010 Share Posted April 23, 2010 bu508daca nu il dovedesti tre' sa iti schimbi porecla Link to comment Share on other sites More sharing options...
Maricel Posted April 23, 2010 Share Posted April 23, 2010 Tranzistorul din linii trebuie să fie cu diodă şi rezistenţă BU2515DX şi verifică condensatorul de pe colector tranzistorului linii şi cele spuse de colegi. Baftă! Link to comment Share on other sites More sharing options...
belowsky Posted April 23, 2010 Share Posted April 23, 2010 Daca tubul are gat subtire,posibil bobiba de deflexie carbonizata intr-un punct ,traba scoasa de pe tub sa se vada.Sau traf-linii are scapari de inalta tensiune. Link to comment Share on other sites More sharing options...
ROBEERT Posted April 23, 2010 Share Posted April 23, 2010 Prietenul C 408 ( 1mf / 160 volti ) l-ai schimbat??? Link to comment Share on other sites More sharing options...
dumi_bv Posted April 25, 2010 Share Posted April 25, 2010 Nu ar strica sa folosesti o rezistentasmechera de 100 ohmi/20W ptr. protectia finalului linii la pornire. Este o metoda foarte eficienta. Link to comment Share on other sites More sharing options...
Guest john39 Posted April 25, 2010 Share Posted April 25, 2010 Vezi daca tz se ambaleaza termic ! Link to comment Share on other sites More sharing options...
dosa Posted April 26, 2010 Share Posted April 26, 2010 incepe asa: scoti tranzistorul final linii si il lasi pe masa, langa televizor.inlocuiesti toti condensatorii electrolitici din primarul sursei desi nu asta e cauza care ar duce la supraalimentarea televizorului.pe condensatorul de filtraj al tensiunii +B pui un bec de 220V/75-100W si pornesti televizorul.becul trebuie sa se aprinda si pe el masori tensiunea care trebuie sa fie aprox 112 volti ( sau 118?). NU TE APUCI SA INCERCI SA O REGLEZI DIN SEMIREGLABILI!Daca tensiunea e mult mai mare, ne raspunzi pe forum si continuam sa vedem despre ce e vorba.Daca tensiunea este aprox cea de mai sus, o lasi asa si verificam :-C421; (poate fi intrerupt si asta ar duce la distrugerea instantanee a finalului linii)-R426 intreruperea duce la distrugerea prin supraincalzire a finalului linii- ATENTIE CU CE TRANZISTOR INLOCUIESTI FINALUL LINII!-Teoretic poate fi trafo linii, practic nu se prea duc ( eu nu am intalnit trafo linii in scurt desi am facut garantii la tv-urile astea)-verifica si traseele de cablaj din jurul tranzistorului final ( spre condensatorul mai sus mentionat)- a se verifica si deflexia si condensatorul de cuplaj cu deflexia Link to comment Share on other sites More sharing options...
Archived
