son Posted April 21, 2010 Share Posted April 21, 2010 Buna ziua am nevoie de un dump ptr.acest monitor; procesor Nebula 73-3 ; memorie 24c08 Mentionez ca cu softul original acest monitor nu porneste iar cu softul de la c700d porneste dar a iesit fum dintr-un driver trafo dupa trafo linii. Va multumesc anticipat Quote Link to comment Share on other sites More sharing options...
Join the conversation
