cosvi Posted April 2, 2010 Share Posted April 2, 2010 Va salut, am un tv orion model tv2070mtx care nu porneste din standby. Ceva sugestii? Daca aveti schema acestui tv v-as fi recunoscator. Link to comment
cosvi Posted April 2, 2010 Author Share Posted April 2, 2010 Normal ca l-am dat jos dar fara schema ce sa verific? Link to comment
FLORIN IORDACHE Posted April 2, 2010 Share Posted April 2, 2010 Poftiti schema ceruta. Va doresc mult succes si un Paste Fericit!!! Link to comment
cosvi Posted April 2, 2010 Author Share Posted April 2, 2010 Multumesc pt schema. Vreo idee despre acest defect? Link to comment
naetv Posted April 2, 2010 Share Posted April 2, 2010 Normal ca l-am dat jos dar fara schema ce sa verific? Link to comment
tv1 Posted April 2, 2010 Share Posted April 2, 2010 Poftiti schema ceruta. Va doresc mult succes si un Paste Fericit!!! Multumim pentru urari,dar schema luata de pe elektrotanya este pentru sasiul Orion Professional 7000.Schema pentru Orion TV2070 MTX a fost uploadata aici de colegul tehtronics :Schema tv ORION TV2070 MTX link Link to comment
attila24 Posted October 1, 2012 Share Posted October 1, 2012 Va salut, am si eu o problema cu un orion model color2150tx, am avur defecta memoria, nu se putea programa, nu am gasit nici schema si nici dump, in schimb am gasit schema si dumpul perfect compatibil de la orion tv2070mtx, cea ce ma duce cu gandul ca de fapt acesta ar fi ce caut eu, am pus dump tv2070mtx si merge totu perfect si cautarea si intrarea in service dar nu am sonor nicicum, cu memoria defecta cu care nu se poate programa am sonor dar cu asta nou nu am, intrebarea mea este daca are cineva un dump testat si functional din toate punctele de vedere. Mentionez ca dumpel care am gasit l-am descaract de pe elektrotanya si am gasit si pe elektroda dar tot aceeasi treaba, multumesc. Link to comment
leoncris Posted October 1, 2012 Share Posted October 1, 2012 Cu ce procesor /memorie , este echipat ? Link to comment
zvasile Posted October 1, 2012 Share Posted October 1, 2012 face cautarea pe cele toate 3 benzi (VHF-L,VHF-H,UHF)?in meniu apare norma de sunet SOUND 1 sau 2 ? Link to comment
attila24 Posted October 2, 2012 Share Posted October 2, 2012 Procesor OEC6047B, memorie 24c04, da in meniu apare SOUND 1 SI 2 dar degeaba schimb ca nu se intampla nimic si schimba bandele intre ele cu memoria asta cu care nu are sunet, cu memoria lui initiala are sunet dar nu schimba bandele numai uhf este, ma mir ca documentatia, schema si memoria se potriveste de la celalalt model(TV2070MTX) Link to comment
zvasile Posted October 2, 2012 Share Posted October 2, 2012 pai asta cred ca e construit pentru Anglia,prinde ceva pe VHF-L si VHF-H sau numai pe UHF?cum face BG/DK?are montat convertor de sunet? Link to comment
attila24 Posted October 2, 2012 Share Posted October 2, 2012 nu cred sa fi facut pt anglia pt ca mergea asa cum trebuie, dintr-o data a aparut aceasta problema, mergeau amantrei benzi, selectorul are toate cele 3 benzi, nu a avut convertor de sunet si aici nici nu trebuie in tg-mures, memoria ce am primit de la dan cod nu merge din pacate Link to comment
