florinellll Posted March 26, 2010 Share Posted March 26, 2010 Cu deosebit respectTv sony KV-29X5K sasiu "tu101" ;procesor saa5497ps/263tv nu porneste,sursa "auxiliara"cu integratul top209p functioneazaSursa "principala"cu strf6654 nu livreaza nici o tensiuneLedul clipeste de doua ori conf codurilor de defect de la sony ar fi vorba de un scurt B+.Finalul linii OK ,bara B+ ok.Am verificat diodele din secudar okEu banuiesc strf6654Ce sugestii imi dati.Multumesc anticipat Link to comment Share on other sites More sharing options...
tv1 Posted March 26, 2010 Share Posted March 26, 2010 N-am auzit pana acum de sasiul tu101,in schimb stiu ca modelul in cauza are sasiul FE-1. Link to comment Share on other sites More sharing options...
nostrom Posted March 26, 2010 Share Posted March 26, 2010 Aprinderea diodei led de doua ori ne avertizeaza ca este activata o protectie Nu cred ca STR-l este defect ,probabil IC603 defect Link to comment Share on other sites More sharing options...
florinellll Posted March 27, 2010 Author Share Posted March 27, 2010 Cauza a fost str-f6654 TV functioneaza normal Ce credeti s-ar putea monta un str-f6653Am vazut ca e ceva mai "slabut"Multumesc Link to comment Share on other sites More sharing options...
nostrom Posted March 27, 2010 Share Posted March 27, 2010 Daca functioneaza normal de ce vreti sa puneti STR-F6653 ?? Link to comment Share on other sites More sharing options...
florinellll Posted March 27, 2010 Author Share Posted March 27, 2010 Cu str-f6653 functioneaza acum, l-am avut din recuperariVoiam sa stiu daca nu o sa apara probleme, celalalt era ceva mai puternic Link to comment Share on other sites More sharing options...
nostrom Posted March 27, 2010 Share Posted March 27, 2010 Totusi in primul mesaj ati spus ca ledul se aprinde de doua ori Daca STR-ul era defect cel care comandaaprinderea ledului conform tabeluliui de erorii nu este uP? Iar uP nu se alimenteaza din secundarul TR.CHOPPER?Chopper care face parte din circuitul STR-lui Sau comanda pentru semnalizarea erorilor este data de alt circuit?Nu inteleg, ma poate lamuri cineva ?Multumesc Link to comment Share on other sites More sharing options...
florinellll Posted March 27, 2010 Author Share Posted March 27, 2010 Daca citeai cu atentie iceputul topicului gaseai si raspunsulAcolo pe schema sunt doua "surse" Cea care alimenteaza procesorul este "aia mica"Probabil crezi ca pun intrebari aiurea ca sa ma aflu in treabaDaca sunt de putin timp pe forum nu inseamna ca m-am apucat acum sa repar televizoare Link to comment Share on other sites More sharing options...
nostrom Posted March 27, 2010 Share Posted March 27, 2010 Nu trebuie sa va enervati confuzia a fost facuta de mine datorita notatiei VDDA ,si VDDM de regula cu VDA,VDDA se noteaza mai frecvent alimentarea uP si mai putin cu VDDM(pin44) A doua cauza a fost circuitul de ST-BY rolul luiin TV si momentul cand intra in functiune Asadar eu nu v-am reprosat nimic din acest motiv am pus intrebarea.M-am grabit lucru rar la mine trebuia mai intai sa studiez DATASHEET si nu intram in polemica cu nimeniCred ca acesta este scopul acestui forum sa discutam si sa gasim o rezolvare la solicitarea postata Link to comment Share on other sites More sharing options...
florinellll Posted March 27, 2010 Author Share Posted March 27, 2010 Nu ma enervezAm pus o intrebare in legatura cu acest defectAm sapat si sa rezolvatApoi am pus rezolvarea pe forum in speranta ca poate fi de ajutor altor colegiSi eu am gasit multe raspunsuri pe acest forumMii de multumiri celor care gestioneaza FORUMUL ELECTRONISTILOR Link to comment Share on other sites More sharing options...
Archived
