palcu ion Posted February 15, 2010 Share Posted February 15, 2010 tv trasnit acum vreo 2-3 ani,reparat,acum a (re)venit cu procesorul .......A049 defect.am schimbat uP cu A049,A070,tv functioneaza ok dar singura hiba ar fi OSD care nu afiseaza decat ferestrele negrede mentionat ca face totusi comenzile chiar daca nu le afiseaza poate a intalnit careva dintre dv ceva asemanator...multumesc Link to comment Share on other sites More sharing options...
mariancalinescu Posted February 15, 2010 Share Posted February 15, 2010 Foarte probabil jungla NN5198K. Link to comment Share on other sites More sharing options...
ROBEERT Posted February 15, 2010 Share Posted February 15, 2010 100 % defect NN5198K. Am avut la greu defectul asta. Si altceva: se duc la ele si receptoarele de infrarosu. Link to comment Share on other sites More sharing options...
depanatortv Posted February 15, 2010 Share Posted February 15, 2010 Schimbati cei doi tranzistori smd T402, T403, de pe Hsync si Vsync! Link to comment Share on other sites More sharing options...
palcu ion Posted February 25, 2010 Author Share Posted February 25, 2010 n-a mai fost decat...jungla defecta!dar doar pe OSD,in rest ok.nu am intilnit !se pare ca tv a fost totusi trasnit din nou dar abia acum a venit la reparatmultumesc de sugestii,defectul asta te poate trimite pe o pista gresita,mai ales daca nu exista de proba pe moment NN Link to comment Share on other sites More sharing options...
ROBEERT Posted February 25, 2010 Share Posted February 25, 2010 n-a mai fost decat...jungla defecta!dar doar pe OSD,in rest ok.nu am intilnit !se pare ca tv a fost totusi trasnit din nou dar abia acum a venit la reparatmultumesc de sugestii,defectul asta te poate trimite pe o pista gresita,mai ales daca nu exista de proba pe moment NNV-am zis domnule Palcu? Acest defect este " fumat " de mine la acest sasiu, dar ma mira cum de nu a fost defect si receptorul de infrarosu in cazul dumneavoastra.Bafta si numai bine. Link to comment Share on other sites More sharing options...
palcu ion Posted February 26, 2010 Author Share Posted February 26, 2010 ca sa intelegem mai bine ceea ce nu intelegem:cand a fost traznit,acum 2-3 ani,a fost defect procesorul si senzorul IR,nimic altceva,acum procesorul si jungla si nimic altceva! daca ati "fumat" atatea,dl.Robeert,poate reusiti sa dati o explicatie si sa o expuneti pe forum Link to comment Share on other sites More sharing options...
ROBEERT Posted February 27, 2010 Share Posted February 27, 2010 ca sa intelegem mai bine ceea ce nu intelegem:cand a fost traznit,acum 2-3 ani,a fost defect procesorul si senzorul IR,nimic altceva,acum procesorul si jungla si nimic altceva! daca ati "fumat" atatea,dl.Robeert,poate reusiti sa dati o explicatie si sa o expuneti pe forum Astea eu cred ca se pot numi defecte tipice la acest sasiu ( in cazul cand acesta sufera o " electrocutare " ). La mine unul tot ce a fost 12.6 " curentat " a fost lege: SDA5535 / A049, NN5198K si receptorul de infrarosu. Explicatia dupa parerea mea este ca " sunt foarte rezistente " la traznete. Din acest motiv crapa tot in el. Repet, in ceea ce priveste defectul la NN5198 s-a manifestat identic ca la tine ( busita partea de insertii RGB pentru OSD si teletext ). Si cu receptorul de infrarosu, la fel, a fost lege. O seara buna. Link to comment Share on other sites More sharing options...
palcu ion Posted February 27, 2010 Author Share Posted February 27, 2010 explicatia faptului ca rec ir a ramas intreg este ca am montat de la prima reparatie unul de 5v se poate inchide topicul Link to comment Share on other sites More sharing options...
ROBEERT Posted February 27, 2010 Share Posted February 27, 2010 Aha, asta era. Link to comment Share on other sites More sharing options...
Archived
