Guest brown Posted December 16, 2009 Share Posted December 16, 2009 Va salut stimati colegi,am primit acest TV si as dori sa trag sunet bistandard si nu stiu cum.Nu am nici schema si nu am gasit nici filtru de 5,5Mh .Procesor SAA 5552-A006,si in cale comuna este NN 5099K,va multumesc si va doresc o zi buna :cry: Link to comment Share on other sites More sharing options...
naetv Posted December 16, 2009 Share Posted December 16, 2009 sasiu beko 12.4/12.5 - vedeti la pini 27-28 NN 5099K - schema aici viewtopic.php?f=17&t=44893&st=0&sk=t&sd=a&hilit=beko+12+4&start=15 Intrare in meniu cu telecomanda originala - MENIU 7,5,9,2 - sau "cu orice telecomanda RC5 PHILIPS cu tasta contrast" se trece din BG in BG-DK si vazut rezultatul , posibil sa fie nevoie sa se schimbe si FUS-ul . Procedeul , mai in amanunt ,daca nu vrea , in depanatorul nr.23 pag 2 . Link to comment Share on other sites More sharing options...
Guest comfel Posted December 16, 2009 Share Posted December 16, 2009 fusul se inlocuieste doar in cazul cand prima cifra este 1 de ex..G1968 M am inilnit in multe cazuri cand afisa pe ecran multi standard dar de fapt erau numai in norma vest ,m/ai ales cele aduse din Italia ......inainte de a umbla in service este bine de dat capacul jos si a se uita la fus Link to comment Share on other sites More sharing options...
Guest brown Posted December 16, 2009 Share Posted December 16, 2009 VA MULTUMESC MULT TUTUROR CARE CHIAR AJUTA,JOS PALARIA Link to comment Share on other sites More sharing options...
Archived
