Guest pauliasi Posted November 30, 2009 Share Posted November 30, 2009 Buna ziua si bine v-am gasit!Am o problema cu un televizor Panasonic TX-21S4TP, daca ma puteti ajuta cu ceva idei.In momentul in care incerc sa-l pornesc, initial porneste, se aude un releu cum comuta, dupa care (cateva clipe) comuta din nou releul respectiv, televizorul se stinge si ledul de power (ledul rosu de langa butonul de power) clipeste.Daca televizorul este lasat mai mult timp stins, in momentul in care ii dau drumul, apuca sa se vada putin din postul pe care este setat, dupa care se inchide. Daca actionez on/off de cateva ori, nu se mai zareste nimic, releul comuta de doua ori, televizorul sta stins si ledul clipeste.Orice idee este bine venita.Va multumesc! Link to comment
Guest pauliasi Posted November 30, 2009 Share Posted November 30, 2009 Am mai gasit pe internet o persoana care are aceeasi problema ca a mea, din pacate nu i-a raspuns nimeni :cry: http://www.tv-forums.com/forum/TV_Equipment_C4/TV_Repair_Forum_F3/Panasonic_TX-21S4TP_P39091/ Citez: "Hi, I have a Panasonic TX-21S4TP TV, chassis Z7. Sometimes (many times) it doesn't start. When front mains switch is pushed, the red LED light goes low, the relay switches, but immediately (aprox 1 sec.) it switches back, and front LED starts blinking. Other times it starts normally, is working fine some time (30 min - 1h) and then suddenly the relay switches, TV goes off with front LED blinking. Any hint? Tks. " Ba chiar domnul respectiv a reusit sa explice mai bine defectul decat mine. Link to comment
Alenicand Posted November 30, 2009 Share Posted November 30, 2009 ce culoare are sasiul? Link to comment
Guest pauliasi Posted November 30, 2009 Share Posted November 30, 2009 Negru, cred... dar ce relevanta are? Link to comment
mariancalinescu Posted November 30, 2009 Share Posted November 30, 2009 Lipeste integratul de cadre. Link to comment
Guest pauliasi Posted November 30, 2009 Share Posted November 30, 2009 Multumesc, dar nu stiu care este acesta... TDA8359? Link to comment
Guest pauliasi Posted November 30, 2009 Share Posted November 30, 2009 Se pare ca acesta era defectul, iti multumesc tare mult! Link to comment
