mgigeone Posted October 21, 2009 Share Posted October 21, 2009 va salut ! am o problema cu un philips chasis L9.2E AA , porneste , merge cam un min si cade in stby , imagine corecta sunet la fel ..am rescris memoria , fara succes , daca pun o memorie goala intra automat in service si poate sa mearga asa si o ora ca nu se mai opreste... ce draq poa sa provoace defectul ? ca sigur a mai fost intalnit de catre dv ....(are tda8842 in jungla , SAA5xxx procesor nu mai stiu exact nr ca e la client acasa , MC44603 in sursa ) sa fie din procesor ? Link to comment Share on other sites More sharing options...
enafelice Posted October 21, 2009 Share Posted October 21, 2009 Incearca placa pe un alt tub,recent am patit la fel Cred ca sesizeaza un curent de fascicul mare.Oricum am inlocuit tubul si a mers(este al 2-lea caz intilnit numai la philips) Link to comment Share on other sites More sharing options...
ROBEERT Posted October 21, 2009 Share Posted October 21, 2009 Sau vreun defect pe IDENT, ce ziceti? Link to comment Share on other sites More sharing options...
mgigeone Posted October 22, 2009 Author Share Posted October 22, 2009 sa stiti ca s-ar putea sa aveti dreptate , are culorile cam nashpa mai ales pe rosu .... azi il pun pe alt tub...... Link to comment Share on other sites More sharing options...
mgigeone Posted October 22, 2009 Author Share Posted October 22, 2009 nu l-am pus pe alt tub dar i-am servit o regenerare competenta si acum merge brici !! mersi pt sfat si multa sanatate !! Link to comment Share on other sites More sharing options...
quinn Posted October 24, 2009 Share Posted October 24, 2009 Spune-ne si noua cum l-ai regenerat ca ne-ai facut curiosi ! Link to comment Share on other sites More sharing options...
quadrall Posted October 24, 2009 Share Posted October 24, 2009 TOP SECRET Link to comment Share on other sites More sharing options...
mgigeone Posted October 25, 2009 Author Share Posted October 25, 2009 nu-i nici un secret , am o scula cumparata de la fratzii nostri moldoveni , ceva rusesc , cu imensa suma de 50" di dalari " , regenereaza destul de bine manual , ce se mai poate recupera , ce-i cazut de tot .... . o duminica placuta va doresc ! Link to comment Share on other sites More sharing options...
Archived
