zvasile Posted October 19, 2009 Share Posted October 19, 2009 Procesor-ST92195C7B1/MTH-FORESEE/WXSJungla-STV2246HMemorie-24C08,Bv-TDA8174A,Sunet-CD7522CSPe sasiu,langa traf mai are o serie-T2S01(06)Am incercat mai multe dumpuri si nu sa potrivit niciunul.Cu toate dumpurile care le-am incercat,tv-ul functioneaza de parca ar fi pe AVAre cineva un dump..?Multumesc! Link to comment
zvasile Posted October 19, 2009 Author Share Posted October 19, 2009 numai cu primul dump functioneaza tv-ul....dar nu m-ai merge din telecomanda ca trebuie intrat in m.service pentru multe reglaje, Link to comment
cristronic Posted October 19, 2009 Share Posted October 19, 2009 Incercati si cu acestea. Link to comment
tehtronics Posted October 19, 2009 Share Posted October 19, 2009 Vasile,... dar acesta ? Link to comment
zvasile Posted October 19, 2009 Author Share Posted October 19, 2009 sunt ok,doua de la cristronic si asta ultimul,cu un mic reglaj din m.service pe BV,acum sa vad cum intru in m.service.......Va multumesc! Link to comment
tehtronics Posted October 19, 2009 Share Posted October 19, 2009 sa inteleg ca, dupa rescrierea memoriei, nu mai merge telecomanda ?deci nu mai poti accesa meniul service, pentru reglaje ...? Link to comment
zvasile Posted October 19, 2009 Author Share Posted October 19, 2009 sa inteleg ca, dupa rescrierea memoriei, nu mai merge telecomanda ?deci nu mai poti accesa meniul service, pentru reglaje ...?totul e ok acum,merge si telecomanda.....problema e ca nu stiu cum sa intru in m.service..... Link to comment
tehtronics Posted October 19, 2009 Share Posted October 19, 2009 tasta ascunsa pe telecomanda- stanga jos, idem ca la TV2Kdaca aveti telec programabila Made For You, va spun secventa de intrare cu aceasta Link to comment
zvasile Posted October 19, 2009 Author Share Posted October 19, 2009 am reusit,tasta ascunsa pe telecomanda era in dreapta jos,multumesc mult! Link to comment
quinn Posted March 17, 2013 Share Posted March 17, 2013 am si eu aceeasi pb cu acest zander ,dupa rescrierea memoriei nu merge telecomanda Link to comment
zvasile Posted March 17, 2013 Author Share Posted March 17, 2013 incearca cu astea de aici; viewtopic.php?f=17&t=89401#p936905 Link to comment
FLORIN IORDACHE Posted March 17, 2013 Share Posted March 17, 2013 Va salut ! Incercati si cu aceste doua dumpuri .Succes ! Link to comment
quinn Posted March 17, 2013 Share Posted March 17, 2013 puteti sa-mi indicati mai precis,deoarece cu cel postat de domnul Dan nu functioneaza telecomanda Link to comment
