Guest petami67 Posted October 17, 2009 Share Posted October 17, 2009 salutare am nevoie,daca ma poate ajuta cineva cu o schema de TELEFUNKEN HR780 rdsmultumiri anticipate Link to comment Share on other sites More sharing options...
zvasile Posted October 17, 2009 Share Posted October 17, 2009 salutare am nevoie,daca ma poate ajuta cineva cu o schema de TELEFUNKEN HR780 rdsmultumiri anticipatePoftim m.service; Link to comment Share on other sites More sharing options...
Guest petami67 Posted October 17, 2009 Share Posted October 17, 2009 le-am descarcat dar nu le pot dezarhivaan ce format este------scuze m-am grabits-a rezolvat Link to comment Share on other sites More sharing options...
Guest petami67 Posted October 17, 2009 Share Posted October 17, 2009 imi poate da cineva un sfat cuprivire la acest rds,adica il pornesc imi apare scris PHONE,iar daca dau o alta comanda gen CD,AUX imi dispare si PHONE si nu mai am nimic scris niai pe dysplay nici CD PHONE sau orice altcevadaca se poate multumiri Link to comment Share on other sites More sharing options...
augustin Posted June 24, 2011 Share Posted June 24, 2011 Sanatate!!! As avea nevoie si eu de manualul pt acest amplificator, dar se pare ca nu mai merge nici link-ul si nici fisierele postate de Dl Vasile...Ma poate ajuta cineva?? Multumesc!!!!!!! Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted June 24, 2011 Share Posted June 24, 2011 Sanatate!!! As avea nevoie si eu de manualul pt acest amplificator, dar se pare ca nu mai merge nici link-ul si nici fisierele postate de Dl Vasile...Ma poate ajuta cineva?? Multumesc!!!!!!!Va salut ! Aveti service manual solicitat de dvs,dati un click aici : http://elektrotanya.com/telefunken_hr78 ... nload.html .Apasati pe Get manual jos in dreapta pe pagina deschisa.Succes ! Link to comment Share on other sites More sharing options...
augustin Posted June 24, 2011 Share Posted June 24, 2011 Sanatate!!! Stie cineva ce tensiuni alternative are traful din acest amplificator?...Multumesc!! Link to comment Share on other sites More sharing options...
zal Posted June 24, 2011 Share Posted June 24, 2011 2x32Vca la vreo 3A minim ptr final, 2x18Vca la vreo 0,5A ptr stabilizatoarele de +/-15V, 4Vca la 0,5A ptr filamentul afişorului.Ce nu mai porneşte ampliful? Şuntează siguranţa termică din primarul trafo şi nu mai trebuie să-l înlocuieşti. Link to comment Share on other sites More sharing options...
Archived
