Guest CorteZ_CTZ Posted August 21, 2009 Share Posted August 21, 2009 Va salut,sunt nou pe forum si am o mica problema.Aveti cumva din intamplare codurile de la o telecomanda TV LCD 10W Well Quote Link to comment Share on other sites More sharing options...
Join the conversation
