Reynolds Posted July 26, 2009 Share Posted July 26, 2009 am un monitor care dupa ce porneste(avand semnal video) merge putin apoi intra singur in standby.am incercat sa misc de cablu pt semnal nimikporneste doar daca ii misc placuta de la tubam schimbat soclul pt pinii de la tub dar face la felce as putea sa-i fac ca sa functioneze corect? Link to comment
maresmircea57 Posted July 26, 2009 Share Posted July 26, 2009 Uitati-va cu mare atentie, de un eventual contact imperfect, sau fisura. Link to comment
Reynolds Posted July 30, 2009 Author Share Posted July 30, 2009 am cautat am mai refacut lipituri (doar pe placuta spate tub)tot nu mergemerge doar daca apas pe colturiam pinii la tub negrii Link to comment
zvasile Posted July 30, 2009 Share Posted July 30, 2009 am cautat am mai refacut lipituri (doar pe placuta spate tub)tot nu mergemerge doar daca apas pe colturiam pinii la tub negriicuratiti pinii cu smirghel fin Link to comment
sorinpavel Posted July 30, 2009 Share Posted July 30, 2009 Este monitor CRT? Nu cumva ai probleme cu filamentul? Cand se opreste apare"NO SIGNAL"?Placa video din calc este buna?Succes Link to comment
Reynolds Posted July 31, 2009 Author Share Posted July 31, 2009 este monitor CRT 14 incham incercat si la alt pc unde sunt sigur ca placa video este buna face la felam sa incerc sa curat pinii Link to comment
maresmircea57 Posted July 31, 2009 Share Posted July 31, 2009 Sau dati putin spray contact. Link to comment
sorinpavel Posted July 31, 2009 Share Posted July 31, 2009 Cate piuituri face?Verificati si memoria Link to comment
