Guest vlademagda Posted July 15, 2009 Share Posted July 15, 2009 buna...am o mica problema cu un tv Kontrast....tv - ul merge dar verticalul e mai mic...si tr de linga la 78040 care e pe acelasi radiator se incalzaste ca naiba...piesele de linga el din primar si secundar sint in valori normale...ce pot faca ? Quote Link to comment Share on other sites More sharing options...
paun nelu Posted July 15, 2009 Share Posted July 15, 2009 Ce titlu e asta,e un alt forum ?!intra in m.s. si citeste si aici viewtopic.php?f=17&t=12666 Quote Link to comment Share on other sites More sharing options...
Join the conversation
