Reynolds Posted July 12, 2009 Share Posted July 12, 2009 am un tv firstline care a avut unele probleme la calea comuna(integrat ars ta7680).am reglat cat de cat calea comuna am sunet bun dar imaginea e cu niste dungi mici si albe(transversale) si mai apar si unele interferente cu alte posturi.Nu receptionez toate posturile si intre posturi am ecran alb complet.cum as putea sa fac reglarea optima? Quote Link to comment Share on other sites More sharing options...
Reynolds Posted July 15, 2009 Author Share Posted July 15, 2009 nu vrea nimeni sa ma ajute? Quote Link to comment Share on other sites More sharing options...
paun nelu Posted July 15, 2009 Share Posted July 15, 2009 ai vobuloscop? Quote Link to comment Share on other sites More sharing options...
Reynolds Posted July 15, 2009 Author Share Posted July 15, 2009 nu am vobuloscopfara nu se poate ?macar o idee am reglat in toate varianteledar de dungi nu am scapate ceva cum era inainte la antena tv pt tvr1,2 la o receptie slaba Quote Link to comment Share on other sites More sharing options...
paun nelu Posted July 15, 2009 Share Posted July 15, 2009 nu am vobuloscopfara nu se poate ?macar o idee am reglat in toate varianteledar de dungi nu am scapate ceva cum era inainte la antena tv pt tvr1,2 la o receptie slabalasal si dul la un service! Quote Link to comment Share on other sites More sharing options...
Reynolds Posted August 29, 2010 Author Share Posted August 29, 2010 din pacate am fost pe la vreo 3 service-uri si niciunul din mesteri nu s-a bagat sa-l repare. Daca imi puteti recomanda alta solutie, eventual cum a fost inainte cu un modul cale comuna separat sau alta solutie am gasit si schema http://hotfile.com/dl/65459872/3c8020d/Tensai_C43M.pdf.html Quote Link to comment Share on other sites More sharing options...
misuraelectronic Posted August 29, 2010 Share Posted August 29, 2010 @ nenea reynolds...!ce fel de depanator sinteti dvs daca n-ati invatat pina acum ca IN CALEA COMUNA A UNUI TVC NU SE UMBLA LA REGLAJE NICIODATA -NICIODATA...?!?! daca ati umblat in bobine...pa ,ura si la gara ...nici cu militia nu mai refaceti dvs curba s initiala...! reglajele sint extraordinar de fine...!curba s se regleaza numai cu woblerul si de catre un ultra-meserias... daca v-au refuzat 3 meseriasi pina acum , inseamna ca mai aveti 3 solutii mari si late...1-- ori folositi tvc-ul pe post de monitor av...eventual sa folositi un tuner extern...!2-- ori cautati pe cineva ultra-meserias care are wobler si care stie sa regleze ca lumea cai comune...!3-- ori il abandonati definitiv / casati pentru piese / aruncati la tomberon ... Quote Link to comment Share on other sites More sharing options...
PETRE66 Posted August 29, 2010 Share Posted August 29, 2010 ka2914 sau ta7680 ....))) Intrebare : cu ce semnal ai constat acele dungi transversale ...antena si pe ce canal sau cablu ? asa cum ai stricat c.c (defectat) , se poate si repara . Iti tre foarte multa rabdare si totodata norok pt.al dovedi . Ai doua bobine de reglat sau sa le procuri de la un alt aparat cu aceeasi c.c . Am aruncat ochii printre sasiele mele ....dar din nefericire pt tine ,nu detin niciunu' cu impricinatul. Totusi la bobine se umbla uneori.....dar cu simt . Bf ! Quote Link to comment Share on other sites More sharing options...
geluklamacik Posted August 29, 2010 Share Posted August 29, 2010 CI. sch.in c.c la tvc. dereglat din bobine, asta nu e bine, dar cu foarte multa rabdare si poate o jumate de zi de reglaje poate poate obtii ceva . in aceste bobine umbli cu simt doar dupa ce ai sch.ci. si merge relativ bine numai dupa aia un reglaj foarte fin poti face dar cu o surubelnita care nu e din metal, dar nici o data nu va merge pe toate canalele cum a mers inainte, si mai e si calitatea CI. Quote Link to comment Share on other sites More sharing options...
tv1 Posted August 29, 2010 Share Posted August 29, 2010 din pacate am fost pe la vreo 3 service-uri si niciunul din mesteri nu s-a bagat sa-l repare. Daca imi puteti recomanda alta solutie, eventual cum a fost inainte cu un modul cale comuna separat sau alta solutie am gasit si schema http://hotfile.com/dl/65459872/3c8020d/Tensai_C43M.pdf.html Il ai de vreo doi ani defect .....Sansele ca sa-l repari tu sant nule.TV Firstline 1433GR link tras in banda TV link Quote Link to comment Share on other sites More sharing options...
Reynolds Posted August 30, 2010 Author Share Posted August 30, 2010 dar un modul compatibil prin care sa ocolesc circuitul initial al TV-uluiacest TV a mai avut o reparatie acolo si asa a fost reparat prin montarea unui modul cale comuna separat(cel cu TA8611AN despre care am mai spus). acel modul functiona impecabil doar ca nu avea sunet pe unele canale, avea o imagine mult mai clara ca cea pe care am obtinuto acum cu calea comuna originala a TV-ului.daca as gasi un astfel de modul reparatia ar fi foarte usoara doar urmarinduse intrarile si iesirile integratului. Quote Link to comment Share on other sites More sharing options...
Join the conversation
