Guest tonyto Posted July 12, 2009 Share Posted July 12, 2009 Acum cateva zile am cumparat din cora un tv platinum ctv 21 s2A functionat ok ..o ziProblema este ca acum se vede alb negru.Cand il aprind trece automat pe AV. pe modul Tv imi apare fara semnalce sa fac? Quote Link to comment Share on other sites More sharing options...
Nonny149 Posted July 12, 2009 Share Posted July 12, 2009 Aparatul are garantie! Trebuie dus la service! Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted July 12, 2009 Share Posted July 12, 2009 V-am dat un raspuns aici :http://forum.microprocesoare.ro/index.php?topic=1563.msg6925#msg6925 Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 12, 2009 Share Posted July 12, 2009 omul e dator sa incerce! Quote Link to comment Share on other sites More sharing options...
Guest tonyto Posted July 14, 2009 Share Posted July 14, 2009 Mda.Multumesc pt sfaturi. Am incercat tot ce tinea de culoare. Din meniu,culorile sunt setate! Ramane sa-l duc la service cu toate ca nu mi se pare normal sa apelezi la un service dupa 24 ore de la achizitionare.Ma gandeam ca poate stie cineva vreo schema pt a reveni la setarile originale,sau pt resetare. 10q Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted July 14, 2009 Share Posted July 14, 2009 Pe teletext are culoare? Sau pe AV. Quote Link to comment Share on other sites More sharing options...
Guest tonyto Posted July 14, 2009 Share Posted July 14, 2009 Da.pe teletext are culoare. pe av nu Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted July 14, 2009 Share Posted July 14, 2009 Aparatul are garantie! Trebuie dus la service!Da, este o problema pe care nu o puteti rezolva d-stra. Umati sfatul lui Nonny149 Quote Link to comment Share on other sites More sharing options...
Guest tonyto Posted July 14, 2009 Share Posted July 14, 2009 Multumesc!Pana la urma o sa va urmez sfatul. speram sa fie mai simplu. Quote Link to comment Share on other sites More sharing options...
JAD Posted July 14, 2009 Share Posted July 14, 2009 Doar de curiozitate; s-a defectat in timpul unei furtuni? In locul unde functioneaza televizorul reteaua electrica si/sau reteaua de cablu tv este aeriana? Sunt aproape sigur ca asta este cauza (traznete in zona). Oricum, apelati la service si nu spuneti ca s-a intamplat pe timp de furtuna cel mai bine spuneti ca nu stiti cand s-a intamplat defectul. Quote Link to comment Share on other sites More sharing options...
Nonny149 Posted July 14, 2009 Share Posted July 14, 2009 eeee strecoara o mica atentie depanatorului si-l face chiar daca sa defectat din cauze care nu fac obiectul garantiei. Quote Link to comment Share on other sites More sharing options...
Guest tonyto Posted July 14, 2009 Share Posted July 14, 2009 Doar de curiozitate; s-a defectat in timpul unei furtuni? In locul unde functioneaza televizorul reteaua electrica si/sau reteaua de cablu tv este aeriana? Sunt aproape sigur ca asta este cauza (traznete in zona). Oricum, apelati la service si nu spuneti ca s-a intamplat pe timp de furtuna cel mai bine spuneti ca nu stiti cand s-a intamplat defectul.era chiar soare cand a luat-o razna so..ce e defect la el? Quote Link to comment Share on other sites More sharing options...
Guest tonyto Posted July 14, 2009 Share Posted July 14, 2009 Doar de curiozitate; s-a defectat in timpul unei furtuni? In locul unde functioneaza televizorul reteaua electrica si/sau reteaua de cablu tv este aeriana? Sunt aproape sigur ca asta este cauza (traznete in zona).Da,folosesc digi tv,dar repet era soare. Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted July 14, 2009 Share Posted July 14, 2009 Daca am sti ce sasiu este, sau ce procesor are, poate ca vam da un raspuns. Folositi digi cu receptie prin satelit? Cu intrare pe euroscart? Quote Link to comment Share on other sites More sharing options...
Guest tonyto Posted July 14, 2009 Share Posted July 14, 2009 Daca am sti ce sasiu este, sau ce procesor are, poate ca vam da un raspuns.nu stiu unde gasesc toate astea:( pe capacul din spate e un cod de bare iar dedesubt niste cifre si litere Quote Link to comment Share on other sites More sharing options...
Join the conversation
