albine Posted July 12, 2009 Share Posted July 12, 2009 AM UN TELEVIZOR SAMSUNG CX-5312W,CARE ARE UN DEFECT NU PORNESTE CAND APAS PE TELCOMANDA .SAU APAS PE BUTONUL TELEVIZORULUI.CA SI CUM TELEVIZORUL NU S-AR ALIMENTA CU CURENT ,LEDUL DE ASTEPTARE ESTE STINS.DACA DESFAC CAPACUL TELEVIZORULUI ,TELEVIZORUL INCEPE SA FUNCTIONEZE,A DOUA ZI LUCRURILE SE REPETA.AS DORI SCHEMA PENTRU ACEST TV.PRECIZEZ CA SUNT INCEPATOR. Link to comment
maresmircea57 Posted July 12, 2009 Share Posted July 12, 2009 Contacte imperfecte pe partea de alimentare, in primar sau secundarul sursei. Link to comment
albine Posted July 13, 2009 Author Share Posted July 13, 2009 contact imperfect partea de alimentare ,primar sau secundar ,la ce va referiti dupa schema???intrebare pentru domnul MARESMIRCEA 57???? Link to comment
maresmircea57 Posted July 13, 2009 Share Posted July 13, 2009 Este cam greu sa spun, uite, pune pistolul aici, refa lipitura asta, si gata, tv. va merge. Asa ca, uitati-va cu mare atentie, la lipiturile de pe placa, in zona chopperului, sau a TDA-ului(4601), la intrerupatorul de retea, transformatorul separator de retea, puntea redresoare, termistorul P802, siguranta F801....... Link to comment
