Guest mat66 Posted July 12, 2009 Share Posted July 12, 2009 buna ziua am o problema la un panasonic model TX 21JT1P nu am sunet si nici culoare din telecomanda nu pot sa modific sunetul pe alta norma ca nu intra in meniu de schimbat norma de sunet si de culoare va rog daca aveti careva dampu de la el va multumesc Quote Link to comment Share on other sites More sharing options...
megastar Posted July 12, 2009 Share Posted July 12, 2009 Dump pentru TX21JT1 de la Master tv : Quote Link to comment Share on other sites More sharing options...
Join the conversation
