Guest gaunash Posted July 10, 2009 Share Posted July 10, 2009 Buna seara, am aceste 4 chinezarii in atelier si toate au in comun urmatoarele piese:edelstein 21ea180 cu procesor tda11106ps/n2/3abs26 memorie 24d08asunet tda1030 traf 352414110 telecomanda np51isi toate au in comun baleajul pe verticala ars. Problema e ca nu pot identifica integratul cu 7 pini in cauza. Am gasit scheme pentru varianta cu TDA93xxx ca procesor dar as vrea ceva mai precis daca s-ar putea.Va multumesc Quote Link to comment Share on other sites More sharing options...
gabiTV Posted July 10, 2009 Share Posted July 10, 2009 Nu este LA78040? Quote Link to comment Share on other sites More sharing options...
Guest gaunash Posted July 11, 2009 Share Posted July 11, 2009 LA78040 apare in combinatie cu alt procesor si sunet, de asta ma intreb ca nu cumva sa fie alta varianta. Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted July 11, 2009 Share Posted July 11, 2009 Uitati-va pe cablaj, si luati pin cu pin si vedeti unde duce.De exemplu:-pin1 duce la +, pin2 la masa, pin3.........s.s.m.d. Este mai greu, dar in lipsa de alta informatie... Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 11, 2009 Share Posted July 11, 2009 stv9302a=la78040=tda9302h=tda8172=tda4846j/aj=stv93258172 - 3A,9325 - 2.5A9302 - 2A Quote Link to comment Share on other sites More sharing options...
Join the conversation
