Bird Posted July 10, 2009 Share Posted July 10, 2009 Am de multi ani un tv Sport la care nu-i "stau "liniile am incercat la vremea respectiva de toate ...si nu am stiut ce sa-i mai fac ...iar acum am ultimatum de la sotie ORI IL FAC ORI IL ARUNC poate i-mi dati o schema si vre un sfat ! Va multumesc! Nu as vrea sa-l arunc . Quote Link to comment Share on other sites More sharing options...
FLORINV69 Posted July 10, 2009 Share Posted July 10, 2009 Arunca-l! Glumesc, cred ca am eu o schema, dar trebuie sa caut prin mormanul de hartii! Quote Link to comment Share on other sites More sharing options...
lulu07 Posted July 10, 2009 Share Posted July 10, 2009 la programatorul ala de kko.....stie femeia ce spune Quote Link to comment Share on other sites More sharing options...
megastar Posted July 10, 2009 Share Posted July 10, 2009 Schema tv. Cathay sport alb-negru cu TDA 4503 . http://www.azp.ro/scheme-electronice/schemetvalbnegru/109-scheme-electrica-tv-alb-negru-pentru-televizoarele-an-romanesti.html Quote Link to comment Share on other sites More sharing options...
naetv Posted July 10, 2009 Share Posted July 10, 2009 sau asta Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 11, 2009 Share Posted July 11, 2009 daca programatorul e bun atunci poate fi defect c 127=2.7nf stiroflex sau eventual semireglabilul de reglaj frecventa linii r125 Quote Link to comment Share on other sites More sharing options...
Bird Posted July 11, 2009 Author Share Posted July 11, 2009 Buna ! Am schimbat cam tot ce era de schimbat de la oscilator am schimbat si integratul si..il aduc aproape sincronizat din semireglabil dupa care pleaca in sens invers frecventa modificandu-se vertiginos . Eu am de gand ..fie ca-l fac fie ca nu , sa-l dau degeaba cuiva pe care-l intereseaza ...Amatori ?? Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 11, 2009 Share Posted July 11, 2009 atentie,C=2.7nf trebuie sa fie stiroflex Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 11, 2009 Share Posted July 11, 2009 poti decupla U VAR de la programator si pune un semireglabil (+12v,masa,Uvar selector)ca sa fii sigur ca ai inlaturat posibilitatea ca programatorul sa fie de vina Quote Link to comment Share on other sites More sharing options...
Bird Posted July 11, 2009 Author Share Posted July 11, 2009 Va salut ! Am gasit fisurat cablajul pe pin28 . dar nu e rezolvata problema . Acum il pun in stare relativa de sincronizare , apare un gen de "50Hz " pe marginile verticale si cand se desincronizeaza e si pe linii si pe cadre (asta mai rar ).Odata cu desincronizarea apare si un fel de tarait O FI O DESCARCARE ??. Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 11, 2009 Share Posted July 11, 2009 filtrajul de 4700mf l-ai schimbat? Quote Link to comment Share on other sites More sharing options...
megastar Posted July 11, 2009 Share Posted July 11, 2009 ...dar puntea redresoare ? Quote Link to comment Share on other sites More sharing options...
Bird Posted July 12, 2009 Author Share Posted July 12, 2009 ...dar puntea redresoare ?nu se vede pe osciloscop nici un riplu pe tensiunea de 10,5V ......???? Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 12, 2009 Share Posted July 12, 2009 uneori trebuie sa mai ascultam si de sotii,ca altfel ..... sau Quote Link to comment Share on other sites More sharing options...
dariuspopescu Posted July 16, 2009 Share Posted July 16, 2009 incearca sa ii schimbi driverul tz final linii (u501) .Daca nu ai unul de Sport monointegrat, incearca schimbarea cu unul de tv cu 5 CI. Quote Link to comment Share on other sites More sharing options...
Join the conversation
