quinn Posted July 7, 2009 Share Posted July 7, 2009 Acest tv nu receptiona semnalele de la telecomanda.Dupa ce am constatat ca telecomanda este ok, am deconectat si reconectat mufa corespunzatoare si s-a rezolvat cu receptionareasemnalelor din telecomanda.Acum,insa la interval de aprox 100 sec "isi da" comanda PP ca si cum ar apasa cineva tasta PP.Sa fie receptorul de IR? Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 7, 2009 Share Posted July 7, 2009 si daca scoti bateriile din tc? Quote Link to comment Share on other sites More sharing options...
zvasile Posted July 7, 2009 Share Posted July 7, 2009 si daca scoti bateriile din tc?sau butonul ''PP''de pe panoul frontal? Quote Link to comment Share on other sites More sharing options...
quinn Posted July 7, 2009 Author Share Posted July 7, 2009 Am verificat si fara baterii si simultan am ecranat chiar si fanta prin care receptioneaza de pe panoul frontal.Eliminarea tastei PP se face destul de greu pt ca toate contactele sunt grupate intr-o minicarcasa,etc dar aceasta tasta nu are nici o contributie la aceasta anomalie pt ca atunci cand o actionez functioneaza normal , nu se blocheaza si in plus ea nu poate oferi acea ritmicitate de care vorbeam mai sus.Multumesc! Quote Link to comment Share on other sites More sharing options...
ROBEERT Posted July 7, 2009 Share Posted July 7, 2009 Salut, dupa ce-l pornesti, deconecteaza-i taciurile de pe panoul frontal si telecomanda las-o fara baterii. Tine-l in probe asa si vezi daca dispare defectul.Asteptam raspuns. Quote Link to comment Share on other sites More sharing options...
zeinerf Posted July 8, 2009 Share Posted July 8, 2009 Receptorul de IR nu face asa cv. mai probabil microsw. dp. panou sau PCA-ul.. Quote Link to comment Share on other sites More sharing options...
costi75 Posted July 8, 2009 Share Posted July 8, 2009 Salut.Am avut acelasi defect la un tv Goldstar.Am inlocuit procesorul(PCA 84C640P) si problema a disparut. Quote Link to comment Share on other sites More sharing options...
palcu ion Posted July 8, 2009 Share Posted July 8, 2009 incalzeste PCA ul cu ansa pistolului si daca face defectul rapid el este de vina Quote Link to comment Share on other sites More sharing options...
naetv Posted July 8, 2009 Share Posted July 8, 2009 Acest tv nu receptiona semnalele de la telecomanda.Dupa ce am constatat ca telecomanda este ok, am deconectat si reconectat mufa corespunzatoare si s-a rezolvat cu receptionareasemnalelor din telecomanda.Acum,insa la interval de aprox 100 sec "isi da" comanda PP ca si cum ar apasa cineva tasta PP.Sa fie receptorul de IR?inainte de umblarea la mufa ,tot asa facea? Pentru a nu umbla la butoane se poate scoate mufa care vine de la tastatura Quote Link to comment Share on other sites More sharing options...
quinn Posted July 9, 2009 Author Share Posted July 9, 2009 Nu ,inainte de a umbla la mufa nu facea . Quote Link to comment Share on other sites More sharing options...
naetv Posted July 9, 2009 Share Posted July 9, 2009 sa nu fi pus mufa gresit -unele nu permit ,dar sint unele la care o poti pune invers sau decalata cu un pin.scoate mufa total si vezi daca mai face Quote Link to comment Share on other sites More sharing options...
Join the conversation
