daisarqx Posted July 4, 2009 Share Posted July 4, 2009 este un pentium 3 la 600 mhz.dupa o pana de curent windows nu mai vrea sa mearga....porneste pana la bara alba care cse plimba si acolo se blocheaza.as vrea sa reinstalez windows dar nu mai asculta sa faca boot de pe cd.....eu zic boot si el nu vrea .atat din bios am pus prima obtiune de boot pe cd cat si din f12 tot prima butare pe cd dar nu vrea...tot la windows merge...idei??????? Quote Link to comment Share on other sites More sharing options...
harman37arun Posted July 4, 2009 Share Posted July 4, 2009 verifica hard discul la pene de curent se fac bad-uri eu am avut un laptop cu problema asta si duca ce am schimbat hardul a mers. Quote Link to comment Share on other sites More sharing options...
daisarqx Posted July 4, 2009 Author Share Posted July 4, 2009 de aia nu vrea sa faca boot de pe cd?,,,asa e hdd se opreste cand nu mai merge windows Quote Link to comment Share on other sites More sharing options...
harman37arun Posted July 4, 2009 Share Posted July 4, 2009 eu as mai avea o idee sa incerci sa instalezi un win98 eu am incercat cu un hard si a mers,nu garantez 100% ca va merge si in cazul tau dar poti incerca.WIN98 e mai mic si daca poti sa il inslalezi il poti scana de bad-uri......oricum daca incerci sa il formatezi in FAT32 cu win 98 si se va opri formatarea garantat e hardul defect...deci poti incerca nu ai ce pierde. Quote Link to comment Share on other sites More sharing options...
daisarqx Posted July 4, 2009 Author Share Posted July 4, 2009 nu am decat 95, e ok? Quote Link to comment Share on other sites More sharing options...
daisarqx Posted July 4, 2009 Author Share Posted July 4, 2009 da cum il instalez daca nu pot porni windows si nici boot nu face? Quote Link to comment Share on other sites More sharing options...
harman37arun Posted July 4, 2009 Share Posted July 4, 2009 incearca si cu win 95,va face format si daca se va opri hardul e clar.hard mort. Quote Link to comment Share on other sites More sharing options...
zvasile Posted July 4, 2009 Share Posted July 4, 2009 este un pentium 3 la 600 mhz.dupa o pana de curent windows nu mai vrea sa mearga....porneste pana la bara alba care cse plimba si acolo se blocheaza.as vrea sa reinstalez windows dar nu mai asculta sa faca boot de pe cd.....eu zic boot si el nu vrea .atat din bios am pus prima obtiune de boot pe cd cat si din f12 tot prima butare pe cd dar nu vrea...tot la windows merge...idei??????? sigur cd. de windows pe care il ai este butabil??? ai mai instalat vre-o data cu el windowsul?si daca cd-ul cu win.este uzat (zgariat).......se intampla sa nu buteze de pe elinainte de a se strica cd-romul de la leptop avea probleme de citire (citea mai greu)?incercati totusi sa faceti un cd. nou cu win si incercati cu el,cd-romurile de leptop sunt mai sensibile fata de alea de pc.varianta cu hd defect e exclusa,poate e defect cd-romul,incercati cu o disketa de 98 sa vedeti daca cu ea buteaza Quote Link to comment Share on other sites More sharing options...
daisarqx Posted July 4, 2009 Author Share Posted July 4, 2009 buna intrebarea ta,zvasile!m-am gandit si eu la asta...am trei discuri bootabile si le-am injcercat pe toate in alt comp si ..fac boot al;te idei?partea proasta e ca nu pot pune nici 95 pe el tot din aceeasi cauza Quote Link to comment Share on other sites More sharing options...
harman37arun Posted July 4, 2009 Share Posted July 4, 2009 ai incercat sa resetezi biosul? Quote Link to comment Share on other sites More sharing options...
daisarqx Posted July 4, 2009 Author Share Posted July 4, 2009 nu.bateria e ascunsa pe undeva... Quote Link to comment Share on other sites More sharing options...
daisarqx Posted July 4, 2009 Author Share Posted July 4, 2009 boot de pe disketa?am incercat dar e formatul mic de disketa si nu am din aceea mica Quote Link to comment Share on other sites More sharing options...
zvasile Posted July 4, 2009 Share Posted July 4, 2009 boot de pe disketa?am incercat dar e formatul mic de disketa si nu am din aceea mica de pe disketa normala,numai butarea se face de pe ea si continua de pe cd pe urma,bateria la bios e sub tastatura si mai ales daca e compaq sau dell, o scoti degeaba,totusi incearca cu un cd nou de win....aici aveti pentru dischetahttp://www.bootdisk.com/bootdisk.htm Quote Link to comment Share on other sites More sharing options...
daisarqx Posted July 4, 2009 Author Share Posted July 4, 2009 am discheta normala dar nu incape in el.... Quote Link to comment Share on other sites More sharing options...
lulu07 Posted July 4, 2009 Share Posted July 4, 2009 acu vreo citeva zile, am avut o problema asemanatoare cu un pc normal, avea biosul alterat.am instalat windows-ul pe al pc. si am avut noroc, s-o pupat cu placa cu pricina Quote Link to comment Share on other sites More sharing options...
Join the conversation
