palcu ion Posted July 2, 2009 Share Posted July 2, 2009 s-a jucat cineva cu AAF si n-a mai ramas niciunul la locul lui in afara de 2030as dori o schema sau tipul celor 3CI (par a fi ka2206 dar doar 2 au cablajul similar) Quote Link to comment Share on other sites More sharing options...
quadrall Posted July 3, 2009 Share Posted July 3, 2009 banuiesc ca tda 2030 este pe subwofer , iar daca ar fii ka2206 ar trebui sa aiba out pow1 -pin2, out pow2-pin11 , pin 12 -Vcc(max 15v), in L-pin 5, in R- pin8,pin 1,7 -GND. In locul lui mai merg:KA2206\1, LA4180 ,LA 4182,LA 4183 ,LA4550 ,LA4555,LA4558. Nu mai retin daca mergea si TEA 2025. Quote Link to comment Share on other sites More sharing options...
remus68 Posted July 3, 2009 Share Posted July 3, 2009 Aici http://www.voti.nl/docs/ka2206.PDF ai schema de utilizare a lui KA2206. Aici http://www.electronica.ro/audio/TDA2030.shtml ai schema de utilizare a lui TDA2030. Quote Link to comment Share on other sites More sharing options...
Guest alecs1 Posted March 31, 2010 Share Posted March 31, 2010 Salut, am un sistem elta 8803cls, nu mai am telecomanda la el,nu pot sa dau mai tare,gasesc alta telecomanda? sau pot folosii niste potentiometre? care ma poate ajuta? raman dator. mersii. Quote Link to comment Share on other sites More sharing options...
misuraelectronic Posted May 14, 2010 Share Posted May 14, 2010 dupa multe ore pierdute probind gramezi de telecomenzi , am descoperit ce merge pentru acest sistem... telecomanda originala este plata si are 8 taste ...! Quote Link to comment Share on other sites More sharing options...
Join the conversation
