johny Posted July 1, 2009 Share Posted July 1, 2009 Sasiu b-7020 Verrtical Tda 8350qJungla TDA8376Nu imi face corectia EWAm inlocuit vertical,care scoate semnal pt.EWAm inlocuit c-uri aferente.Ma poate ajuta cineva?Poate detine cineva o schema?Va multumesc! Quote Link to comment Share on other sites More sharing options...
naetv Posted July 1, 2009 Share Posted July 1, 2009 La Orion tv775 mie imi da ca este sasiu 7000 professional-schema urmeaza -macar de orientare Quote Link to comment Share on other sites More sharing options...
johny Posted July 1, 2009 Author Share Posted July 1, 2009 Multumesc!Pare sa corespunda.Caut in continuare problema pt. ca nu se deschide rastrul crespunzator pe orizontala. Quote Link to comment Share on other sites More sharing options...
megastar Posted July 1, 2009 Share Posted July 1, 2009 Sasiu b-7020 Vertical Tda 8350q Nu imi face corectia EW Am inlocuit vertical,care scoate semnal pt.EW Tda 8350 este si circuit E-W la pinii : 7 si 13 = masa , 12 =intrare reglabila din tda 8376 , iar 11 = iesire la diodele E-W . TDA 8350 este comandat pe date , posibil defecta si memoria ! Prezsntare TDA 8350 -final vertical + final E-W .[attachment=0]TDA8350_1.pdf[/attachment] Quote Link to comment Share on other sites More sharing options...
johny Posted July 7, 2009 Author Share Posted July 7, 2009 Am rezolvat schimband softul.Multumesc celor care m-au ajutat! Quote Link to comment Share on other sites More sharing options...
Join the conversation
