casiu Posted June 27, 2009 Share Posted June 27, 2009 Stie cineva ce se poate pune in loc de STX112, tz prefinal linii la sasiul 11ak30s-2? Pe schema e trecut BC639, dar cu el se incalzeste finalul linii BU808dfi. Tz original STX112 e un darlington cu dioda.Multumesc anticipat. Quote Link to comment Share on other sites More sharing options...
naetv Posted June 27, 2009 Share Posted June 27, 2009 Vezi aici viewtopic.php?f=17&t=23320&st=0&sk=t&sd=a&hilit=STX112&start=0 citeste cu atentie. Quote Link to comment Share on other sites More sharing options...
Join the conversation
