bogdan546 Posted June 27, 2009 Share Posted June 27, 2009 sasiu UOCTOP80PIN, procesor/multifunctional TDA12122H/N200,sursa CQ0765RT as avea nevoie de o schema Quote Link to comment Share on other sites More sharing options...
zvasile Posted June 27, 2009 Share Posted June 27, 2009 sasiu UOCTOP80PIN, procesor/multifunctional TDA12122H/N200,sursa CQ0765RT as avea nevoie de o schemae acelasi sasiu dar sursa e cu CQ1265RTvedeti aici Quote Link to comment Share on other sites More sharing options...
bogdan546 Posted June 27, 2009 Author Share Posted June 27, 2009 la baleajul orizontal nu este la fel al meu este de 14 inch si am o problema cu tranzistorul BO care se incalzeste excesiv si se distruge Quote Link to comment Share on other sites More sharing options...
bogdan546 Posted June 28, 2009 Author Share Posted June 28, 2009 marirea rezistentei dintre baza si masa oare nu ar pute face comanda tranzistorului mai ferma deoarece eu cred ca la acest tv este o greseala din fabricatie altfel nu stiu de ce s-a defectat dupa o jumatate de oara de functiuonare de cand a fost cumparatNu am gasit niciun condensator electrolitic uzat si am observat ca la varianta de 29" este rezistenta aceea de 22 ohmi si la mine este pusa de 82 ohmi Quote Link to comment Share on other sites More sharing options...
daisarqx Posted June 28, 2009 Share Posted June 28, 2009 poate...incearca....imaginea e ok? Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted June 28, 2009 Share Posted June 28, 2009 Ce tranzistor a fost in televizor(cel care s-a ars)? Ce tranzistor ati pus in loc(cel care se incinge)? Quote Link to comment Share on other sites More sharing options...
bogdan546 Posted June 28, 2009 Author Share Posted June 28, 2009 a fost TT2140 si am pus 2sd2586 am vazut ca Tt2140 este hight speed dar totusi eu cred ca s-a ars din cauza ambalarii termice .Nu am gasit inca un echivalent la indemana Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted June 28, 2009 Share Posted June 28, 2009 Am atasat datasheet-urile tranzistoarelor, precum si schema pentru 20-21", la care nu corespunde procesorul, in schimb partea de linii ,cred ca este cea care o aveti in tv. Verificati L414, R413, VD413, C414, C415 si inlocuiti C412, si C417.V-as da o idee. Puneti un tranzistor, fara dioda(de la un monitor de 19"),inpreuna cu o dioda(de la acelas monitor) pe un radiator separat, si legatil in locul finalului de linii. Vedeti daca se mai incalzeste. Quote Link to comment Share on other sites More sharing options...
bogdan546 Posted June 28, 2009 Author Share Posted June 28, 2009 Din pacate doar tranzistorul este lafel in rest difera Singura "rezolvare" ar fi o schema exacta pentru acest model ,dar se pare ca nu se gaseste si trebuie sa abandonez Eu cred totusi ca este o erare de fabricatie si fara schema numi dau seama daca este pusa o componenta de o valoare diferita sau altceva Multumesc pentru scheme. Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted June 28, 2009 Share Posted June 28, 2009 De ce nu incercati ce v-am spus? Quote Link to comment Share on other sites More sharing options...
bogdan546 Posted June 28, 2009 Author Share Posted June 28, 2009 Nu am de unde lua un tranzistor de monitor si sunt convins ca nu se va rezolva deoarece la tranzistoarele de acel tip nu au nimic in plus decat suportul pentru un curent mai mare Tranzistorul original nu-l am ,de cumparat nu cred ca se pune problema si mai ales ca am am dubii ca ar fi din cauza lui deoarece televizorul a functionat doar jumatate de ora de cand a fost cumparat de aceea cred ca este ceva in neregula cu partea de comanda a tranzistorului . Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted June 28, 2009 Share Posted June 28, 2009 OK! Quote Link to comment Share on other sites More sharing options...
Join the conversation
