lefter Posted June 25, 2009 Share Posted June 25, 2009 am reparat sursa si acum ledu se aprinde pe verde fara sa-l pot trece in stemby si nici nu ridica inalta [fit} ,tensiunea pe colector bu 808 este de 113-114v Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted June 25, 2009 Share Posted June 25, 2009 S-a defectat in urma descarcarilor electrice? Quote Link to comment Share on other sites More sharing options...
lefter Posted June 25, 2009 Author Share Posted June 25, 2009 nu la reparat un meserias si in sursa mi-a pus o memorie un pcd sau ceva de genu asta apoi a lucrat pe linga procesor si cuart schimbat si cam atit Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted June 25, 2009 Share Posted June 25, 2009 Pai si acum cine il mestereste? Quote Link to comment Share on other sites More sharing options...
codrin Posted June 25, 2009 Share Posted June 25, 2009 nu la reparat un meserias si in sursa mi-a pus o memorie un pcd sau ceva de genu asta apoi a lucrat pe linga procesor si cuart schimbat si cam atitdaca tot l-ai dus la "meserias" ,acum de ce faci pe meseriasul????du-l domn'le inapoi la respectivii sa-si faca treaba! acum daca tot l-ai dasfacut " schimba-i memoria din sursa" ca sa aiba aia motiv sa ti-l puna-n brate..... asa-i cand scrii fara semne de punctuatie de nu intelegi decat tu. Quote Link to comment Share on other sites More sharing options...
lefter Posted June 25, 2009 Author Share Posted June 25, 2009 va cred insa daca sunteti atit de buni in electronica pe cit sunteti la gramatica dati solutii nu faceti observatii Quote Link to comment Share on other sites More sharing options...
lefter Posted June 25, 2009 Author Share Posted June 25, 2009 nu sunt eu proprietarul tv-ului ,isa al ajuns la mine cu el in situatia data de mine mai sus ,adica cu pcd in sursa in loc de mc44608 si cablaje facute praf Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted June 25, 2009 Share Posted June 25, 2009 Pai ce solutii sa-ti dam? Ce ai postat pana acum e de cascadorii rasului! Auzi--memorie in sursa!!! :bataiep.s Fara suparare, dumneata esti roman? Dupa felul cum te exprimi.?????????? Quote Link to comment Share on other sites More sharing options...
lefter Posted June 25, 2009 Author Share Posted June 25, 2009 este exact ce am gasit in sursa tv-ulu nu glumesc Quote Link to comment Share on other sites More sharing options...
lefter Posted June 25, 2009 Author Share Posted June 25, 2009 dupa ce am inlocuit buz 90, mc 44608 , pc817 scurt total a pornit sursa Quote Link to comment Share on other sites More sharing options...
lefter Posted June 25, 2009 Author Share Posted June 25, 2009 pentru maresmircea 57 crezi ca am un motiv sa postez asa timpenie dar este reala nu este de gluma si la tine poate ajunge un tv de genu celui care a ajuns la mine Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted June 25, 2009 Share Posted June 25, 2009 Pai nu puteai sa spui asa de la inceput? Eu cred ca nimeni de pe acest forum, nu a inteles nimic din ce ai vrut sa spui la inceput. Si ,ce a trebuit sa intrebi, ceva care vad ca ai rezolvat singur? Quote Link to comment Share on other sites More sharing options...
lefter Posted June 25, 2009 Author Share Posted June 25, 2009 nu sursa mi-a dat batai de cap ,pentru ca pe ea am rezolvat-o dar se aprinde ledul direct verde si nu-mi ridica inalta {fit} tensiune colector bu 808 este de 114v si nu ridica inlta asta vreau sa ma ajutai sa rezolv Quote Link to comment Share on other sites More sharing options...
daisarqx Posted June 25, 2009 Share Posted June 25, 2009 COMANDA IN BAZA LA BU 808 ESTE? Quote Link to comment Share on other sites More sharing options...
lefter Posted June 25, 2009 Author Share Posted June 25, 2009 da Quote Link to comment Share on other sites More sharing options...
Join the conversation
