Guest ilie_vygis Posted June 25, 2009 Share Posted June 25, 2009 salutare ma poate ajuta cineva cu o problemacaut o schema pentru dvd Easy touch model et-616 sursa arsa ic1 de pe sursa ars e pocnit nu se mai vede nici un cod pe el ma poate ajuta cineva cam ce se afla acolo IC1 astept raspuns multumesc Quote Link to comment Share on other sites More sharing options...
sorin_da Posted May 16, 2011 Share Posted May 16, 2011 fan7554 http://www.datasheetcatalog.org/datashe ... AN7554.pdf Quote Link to comment Share on other sites More sharing options...
Join the conversation
