zeinerf Posted April 15, 2009 Share Posted April 15, 2009 SALUT.Am un LG sasiu MC-64A,care imi arde tz.de linii.Are cineva o schema??? Quote Link to comment Share on other sites More sharing options...
palcu ion Posted April 15, 2009 Share Posted April 15, 2009 mc64a Quote Link to comment Share on other sites More sharing options...
zeinerf Posted April 15, 2009 Author Share Posted April 15, 2009 SALUT.Am un LG sasiu MC-64A,care imi arde tz.de linii.Are cineva o schema??? Quote Link to comment Share on other sites More sharing options...
palcu ion Posted April 15, 2009 Share Posted April 15, 2009 daca lipiturile la c421 sunt ok si el e bun,cel mai probabil defect e trafo linii hr 8163=7666=7485=7906final linii =d2499 Quote Link to comment Share on other sites More sharing options...
bobo Posted April 16, 2009 Share Posted April 16, 2009 la LG CF21D16X SOUNDMAX am gasit sasiu MC64B.verificati daca +B este corecta,daca C421 este bun si daca finalul linii este comandat corect.schimbati si C408 de pe alimentare driver.final linii 2SD2499 sau BU508D(cu dioda dar fara rez BE).daca totul este corect schimbati trafo linii. Quote Link to comment Share on other sites More sharing options...
palcu ion Posted April 16, 2009 Share Posted April 16, 2009 multumim pentru ajutor Quote Link to comment Share on other sites More sharing options...
zeinerf Posted April 17, 2009 Author Share Posted April 17, 2009 SALUT.Am un LG sasiu MC-64A,care imi arde tz.de linii.Are cineva o schema???Am rezolvat TV-ul .Era traful.Am pus un HR 7906,merge perfect Quote Link to comment Share on other sites More sharing options...
Marius84 Posted March 4, 2014 Share Posted March 4, 2014 Buna seara! Am acelasi tv, am verificat tensiunea sursei pe bec, este ok, am schimbat condensatorii din sursa, cel de 1uF din zona trafo driver, care era la jumatate.Tv. a avut tranzistor final linii ars, am unul de schimb, dar vreau sa va intreb in cazul in care am trafo linii dus(am unul de schimb) cam cat rezista oare finalul linii? Pot sa ii dau drumul cateva secunde, sau se arde instant?Persoana de la care l-am luat a afirmat ca a s-a auzit ca un foc, desi nu miroase nimic a ars. Desi mi s-a recomandat sa imi fac un tester, inca nu l-am facut... Quote Link to comment Share on other sites More sharing options...
modoran Posted March 4, 2014 Share Posted March 4, 2014 Daca trafo linii este defect tranzistorul final linii se poate strapunge instantaneu.Pentru protectia finalului poti folosi temporar o tensiune B+ mai mica sau un bec de 100W serie cu alimentarea B+ (metoda nu e sigura 100%). Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted March 4, 2014 Share Posted March 4, 2014 sau poti sai mai pui un cond de recuperare la jumate sau cit este in tv si poate iti dai seama daca merge sau poate nu se deschide dar ai timp sa vezi daca se incalzeste Quote Link to comment Share on other sites More sharing options...
Marius84 Posted March 4, 2014 Share Posted March 4, 2014 Am inseriat becul, se aprinde, dar nu pleca liniile deloc. Sta aprins cam o secunda si se stinge. Am in baza tranzistorului cca 20kHz, nu am osciloscop. Quote Link to comment Share on other sites More sharing options...
Marius84 Posted March 4, 2014 Share Posted March 4, 2014 Am pus trafo linii nou si se comporta la fel pe bec. Am refacut circuitul la loc scotand becul din circuit, au pornit liniile, dar am desincronizare totala, imaginea este pe rosu total pe posturi, insa OSD-ul este afisat corect, verde curat si galben. Pe catozi am astfel: Rosu 70v, albastru 160, Verde 160. Desincronizarea este si pe tv, si pe av. Sunetul este corect. Sa las acest trafo, sau il pun din nou pe cel vechi, la risc? Quote Link to comment Share on other sites More sharing options...
Marius84 Posted March 4, 2014 Share Posted March 4, 2014 Am pus inapoi trafo original, nu mi-a ars finalul linii, am vrut sa ma conving ca e dus, si iesea fum intr-o veselie din el avand totodata sunet specific de arc electric in interior. Am repus trafo linii FBT 7906 si am mai facut cateva teste>Pe AV este la fel de desincronizat ca pe tv. Daca incerc sa comut pe tv in timp ce am semnal in mufa scart, desi arata ca deruleaza programele, arata imaginea si sunetul de pe AV.Ce parere aveti? Am TDA8362B S7 dus? Poate fi defect de soft? Quote Link to comment Share on other sites More sharing options...
Florinel TV Posted March 5, 2014 Share Posted March 5, 2014 prima data schimba cond driver Quote Link to comment Share on other sites More sharing options...
Marius84 Posted March 5, 2014 Share Posted March 5, 2014 Va referiti la cel de 1uF/160v? A fost schimbat primul, inainte de a schimba traful si finalul linii... Quote Link to comment Share on other sites More sharing options...
Join the conversation
