ROBEERT Posted April 10, 2009 Share Posted April 10, 2009 Va salut stimati prieteni. Am primit asemenea podoaba la atelier cu trafo linii parlit. E asa plin de praf, incat pe eticheta atat am putut descifra: DCF 2117 ( parca ). Pana aici, toate bune si frumoase. Am zis " aaaaaaa, ma uit in catalog sa vad ce HR are echivalent ". Dar surpriza, la acest tip de HR am vazut mai multe terminatii. Acum sper sa fi descifrat corect DCF 2117 dar terminatia n-o pot descifra. Intrebarea este " oare o fi chiar DCF 2117 si daca da, ce terminatie o avea "Deci, stimati colegi, imi puteti spune si mie care stiti ce traf are acest sasiu, ca de inlocuit am inlocuit la greu, dar daca am fost neglijent si nu am notat pe ceva ce traf are, sincer, nu mai tin minte.Multumesc fain! Link to comment
maresmircea57 Posted April 10, 2009 Share Posted April 10, 2009 Daewoo sasiu CP330 cu tub de 20" are trafo DCF2217J=HR7644 , iar pentru tub de 21" DCF2217L=HR7797 Link to comment
bobo Posted April 11, 2009 Share Posted April 11, 2009 pt CP330:20''=DCF2217J , HR 7644 , FBT 764421''=DCF2217L , HR 7797 , FBT 7797telecomanda originala R22 sau P3051 Link to comment
ROBEERT Posted April 11, 2009 Author Share Posted April 11, 2009 La acest sasiu are tubul A48 cu gat subtire. Ce traf ati spune ca merge? Imi cer scuze, dar la lectia cu 19", 20", etc. am lipsit si le cam incurc. Eu ma exprim tot batraneste ( diagonala A48, A51, A37, etc. ).Inca odata, mii de scuze!!! Se mai intampla sa incurci marfa cu ambalajul. Link to comment
maresmircea57 Posted April 12, 2009 Share Posted April 12, 2009 Aveti aici conversia centimetri-inch. http://www.metric-conversions.org/lengt ... inches.htm 48 cm =~19 inch Deci pentru 20" trebuie HR7644 Link to comment
ROBEERT Posted April 12, 2009 Author Share Posted April 12, 2009 Merci mult domnule Mares Mircea ca ati invatat baba ce-s aia inch. Link to comment
ROBEERT Posted April 13, 2009 Author Share Posted April 13, 2009 Televizor rezolvat. I-am cumparat FBT 7644, i l-am montat si a pornit din prima. Multumesc mult domnului Mares Mircea si domnului Bobo. Bafta baieti. Link to comment
