ERIK_ Posted April 6, 2009 Share Posted April 6, 2009 am si eu o combina muzicala philips model FW-M355/34 SI NU MAI AM SONOR IN BOXE DOAR IN CASCA.POATE SA-MI SPUNS SI MIE CINEVA CE ARE?SAU MACAR O SCHEMA Quote Link to comment Share on other sites More sharing options...
tv1 Posted April 6, 2009 Share Posted April 6, 2009 http://www.eserviceinfo.com/downloadsm/ ... -V355.html sant 9 parti ;le download-ezi pe toate si apoi le unesti. Quote Link to comment Share on other sites More sharing options...
ERIK_ Posted April 7, 2009 Author Share Posted April 7, 2009 cine poate sa-mi dea si mie caracteristici la un circuit integrat AN17830A Quote Link to comment Share on other sites More sharing options...
codrin Posted April 7, 2009 Share Posted April 7, 2009 uite aici http://www.alldatasheet.com/view.jsp?Se ... &q=AN17830 Quote Link to comment Share on other sites More sharing options...
palcu ion Posted April 7, 2009 Share Posted April 7, 2009 pe alimentarea an 17830 ai un tranz stp16no5,schimba-l daca e integratul defect,altfel il distrugi si pe cel nou Quote Link to comment Share on other sites More sharing options...
tv1 Posted April 7, 2009 Share Posted April 7, 2009 cine poate sa-mi dea si mie caracteristici la un circuit integrat AN17830ASpecial am unit cele doua topicuri fiindca banuiesc ca nu ai reusit sa downloadezi service manualul de la adresa indicata.In atasament ai schema partii de alimentare si a finalului audio.Eu zic sa nu dai banii pe final pana nu verifici piesele aferente circuitului AN17830A.(in special tranzistorul FET 7302 = STP16NE06 - link datasheet Quote Link to comment Share on other sites More sharing options...
ERIK_ Posted April 9, 2009 Author Share Posted April 9, 2009 acum am descoperit ca merge numai cand vrea el.am masurat tensiunile pe acel trz fet stp16ne06 si vad ca aci imi da tensiunile normale, aci aproape le dubleaza.EX: pinul 1 al c.i audio ba este 17v ba 30v, pe pinii de iesire a c.i audio ba este 7v ba 20v nu mai inteleg nimic.stie cineva ceva? Quote Link to comment Share on other sites More sharing options...
zvasile Posted April 9, 2009 Share Posted April 9, 2009 am si eu o combina muzicala philips model FW-M355/34 SI NU MAI AM SONOR IN BOXE DOAR IN CASCA.POATE SA-MI SPUNS SI MIE CINEVA CE ARE?SAU MACAR O SCHEMAposibil mufa de casti defecta Quote Link to comment Share on other sites More sharing options...
palcu ion Posted April 9, 2009 Share Posted April 9, 2009 ca merge "cand vrea el",am inteles,dar nu ne spui si daca se aude "tot cand vrea el" Quote Link to comment Share on other sites More sharing options...
ERIK_ Posted April 10, 2009 Author Share Posted April 10, 2009 cine stie de ce cand pun condensatorul de filtrare imi blocheaza c.i. audio.fara el se aude in boxe cu zgomotul re traf si cand il montez nu se mai aude?la puntea redresoare are un condens de filtrare.fara el se aude in boxe cand il montez nu se mai aude,imi blocheaza c.i.audio si nici tensiunile nu mai sunt cele normale Quote Link to comment Share on other sites More sharing options...
djlove Posted April 10, 2009 Share Posted April 10, 2009 Nu inteleg ce vrei sa spui acolo. Fi mai clar, explica ce problema ai. Quote Link to comment Share on other sites More sharing options...
tv1 Posted April 10, 2009 Share Posted April 10, 2009 cine stie de ce cand pun condensatorul de filtrare imi blocheaza c.i. audio.fara el se aude in boxe cu zgomotul re traf si cand il montez nu se mai aude?Tu ce faci ?Postezi aiurea ? Ai inceput un topic despre combina asta , nu e normal sa continui acolo unde ai inceput ?Atata timp cat in pinul 1 al AN17830 nu faci ca alimentarea sa fie 17 V ,nu va merge;integratul trece automat pe mute.Ti s-a mai spus o data ca tranzistorul FET da acest defect. Quote Link to comment Share on other sites More sharing options...
djlove Posted April 10, 2009 Share Posted April 10, 2009 cine stie de ce cand pun condensatorul de filtrare imi blocheaza c.i. audio.fara el se aude in boxe cu zgomotul re traf si cand il montez nu se mai aude?la puntea redresoare are un condens de filtrare.fara el se aude in boxe cand il montez nu se mai aude,imi blocheaza c.i.audio si nici tensiunile nu mai sunt cele normale Pai dupa puntea redresoare e normal sa ai si un condensator de filtrare. Ia pune niste poze clare , sa vedem ce probleme ai tu pe acolo. Quote Link to comment Share on other sites More sharing options...
ERIK_ Posted April 10, 2009 Author Share Posted April 10, 2009 cine stie de ce cand pun condensatorul de filtrare imi blocheaza c.i. audio.fara el se aude in boxe cu zgomotul re traf si cand il montez nu se mai aude?la puntea redresoare are un condens de filtrare.fara el se aude in boxe cand il montez nu se mai aude,imi blocheaza c.i.audio si nici tensiunile nu mai sunt cele normale Pai dupa puntea redresoare e normal sa ai si un condensator de filtrare. Ia pune niste poze clare , sa vedem ce probleme ai tu pe acolo.pai am schimbat tranz fet acelas lucru se intimpla Quote Link to comment Share on other sites More sharing options...
tv1 Posted April 10, 2009 Share Posted April 10, 2009 Ce tensiune ai in pinul 1 al AN17830 ? Quote Link to comment Share on other sites More sharing options...
Join the conversation
