lus Posted February 20, 2009 Share Posted February 20, 2009 am de reparat un televizor megavision care la prima vedere are toate tensiunile bune in sursa dar nu-mi pleaca din stby,rog o schema daca are cineva,am pe bara alimentare final linii tensiune 98v si 5v Link to comment Share on other sites More sharing options...
lus Posted February 20, 2009 Author Share Posted February 20, 2009 alimentare str50103,ta8659an,m34300 Link to comment Share on other sites More sharing options...
Nonny149 Posted February 20, 2009 Share Posted February 20, 2009 Poftim schema. Link to comment Share on other sites More sharing options...
codrin Posted February 20, 2009 Share Posted February 20, 2009 nu stiu daca ai noroc.eu am cerut-o cu ceva timp(vreo 2 ani, parca) in urma dar nu s-a rezolvat(si am contactat persoane super avizate).doar sa o aiba cineva scanata .pana faci rost de C52 inspira-te din schema C50. amandoua sunt de la DAEWOO. Link to comment Share on other sites More sharing options...
Nonny149 Posted February 20, 2009 Share Posted February 20, 2009 Daca aveam sasiul C52 il serveam dar asa i-am dat ceva apropiat Link to comment Share on other sites More sharing options...
lus Posted February 20, 2009 Author Share Posted February 20, 2009 am vazut ca a mai fost ceruta si de codrin,oricum e buna si asta decat nimic,multumesc mult de ajutor Link to comment Share on other sites More sharing options...
Tavi Posted February 20, 2009 Share Posted February 20, 2009 sasiul C52 de la Megavision este Daewoo sasiu CP315dar a zis ca este facut cu STR50103 deci mai degraba e sasiu C50ce procesor are ? Link to comment Share on other sites More sharing options...
ROBEERT Posted February 20, 2009 Share Posted February 20, 2009 Salut, vezi sa nu ai vreun scurtcircuit pe vreo secundara a sursei, verifica tensiunea de 300volti, diodele din partea primara, schimba condensatorii din partea primara a sursei. Daca nu, e posibil sa fie STR-ul. Link to comment Share on other sites More sharing options...
tv1 Posted February 22, 2009 Share Posted February 22, 2009 am de reparat un televizor megavision care la prima vedere are toate tensiunile bune in sursa dar nu-mi pleaca din stby,rog o schema daca are cineva,am pe bara alimentare final linii tensiune 98v si 5v Salut, vezi sa nu ai vreun scurtcircuit pe vreo secundara a sursei, verifica tensiunea de 300volti, diodele din partea primara, schimba condensatorii din partea primara a sursei. Daca nu, e posibil sa fie STR-ul.Vezi ce a scris omu' mai sus ? Tu ii spui sa verifice daca are 300 V pe condensator ,iar el iti spune ca sursa merge - din moment ce scoate 98 V (dupa pornirea etajului de linii tensiunea devine 103 V ).Nu mai scrie aberatii din astea pe forum ,doar ca sa iti cresti numarul de postari.Porneste-l cu telecomanda.( Pilot 1830 ) Link to comment Share on other sites More sharing options...
Guest Tudose Vasile Posted March 14, 2009 Share Posted March 14, 2009 V? salut pe to?i forumi?tii electronisti,m?rturisesc c? am intrat pentru prima dat?,pe forum,iar în ceea ce priveste am cateva notiuni de electronic?.Ma adresez ,dvs.cu rug?mintea,de a-mi oferi ?i mie o schem? de tv Megavision model DMQ 2057 TXT.Posed un exemplar ptr.care nu am schem?.?i la care am un defect f.f.ingenios. ?i anume:apare cursa invers? peste imagine,dimensiuhe orizontal? reds?,cu aproximativ 1 cm. pe fiecare parte.?i nu r?spunde la comenzile manuale,sau cu telec. ale meniului.Dac? m? pute?i ajuta,-v? mul?umesc anticipat.. Link to comment Share on other sites More sharing options...
tv1 Posted March 14, 2009 Share Posted March 14, 2009 Megavision model DMQ-2057TXT foloseste sasiul CP-315 de la Daewoo;schema e uploadata mai sus de Tavi. Link to comment Share on other sites More sharing options...
lus Posted March 17, 2009 Author Share Posted March 17, 2009 da,asa e,e c50,inca nu am avut timp sa ma ocup de acest televizor,vad ca are tendinta de a porni inalta daca pun tresa aparatului de masura pe tranzistorii de dupa sursa,mai precis in colectorul lui q802 Link to comment Share on other sites More sharing options...
lus Posted March 17, 2009 Author Share Posted March 17, 2009 am mai facut verificari si cred 99,9% ca e i901 Link to comment Share on other sites More sharing options...
Guest letcanu valerica Posted March 19, 2009 Share Posted March 19, 2009 daca are M34300 , verifica cu atentie TOATE diodele 1N din pinii luiam inlocuit una cu rez inversa ( cca 200 ohmi) dupa care a iesit din st.bLE : in funct. normala , pentru a iesi din stb , butonul de power trebuie tinut apasat cca 3 sec , daca nu fac o confuzie ( asta in lipsa telecomenzii sau a unui defect ) Link to comment Share on other sites More sharing options...
Archived
