Vas Posted December 3, 2008 Share Posted December 3, 2008 Tv are sunet lipsa imagine.Daca pun pe AV si schimb pe canal 1 apare o secunda imaginea si apoi se intuneca.Daca schimb pe canalul 2 nu se vede nimic.Deci numai de pe AV spre TV apare.A-si avea nevoie de o schema ca n-am gasit nicaieri.Cred ca lipsesc impulsuri de H sau V pentru decodor.O alta chestie...ce tip de telecomanda are TV Schneider TV21M301,model M35-21189/M/C-AV/AS?Mii de multumiri.ADY Link to comment Share on other sites More sharing options...
naetv Posted December 3, 2008 Share Posted December 3, 2008 Sper ca asta te ajuta Link to comment Share on other sites More sharing options...
tv1 Posted December 4, 2008 Share Posted December 4, 2008 Telecomanda pentru Schneider 21M301 in atasament. Link to comment Share on other sites More sharing options...
Vas Posted December 4, 2008 Author Share Posted December 4, 2008 dar ce numar sau cod are telecomanda Link to comment Share on other sites More sharing options...
Vas Posted December 4, 2008 Author Share Posted December 4, 2008 cu ce program pot deschide file-ul djvu? Link to comment Share on other sites More sharing options...
tv1 Posted December 4, 2008 Share Posted December 4, 2008 Service manual in format .pdf http://www.canton-distribution.ro/telec ... inale9.htm pozitia 74 telecomanda Schneider Link to comment Share on other sites More sharing options...
Archived
