TOMITA Posted November 29, 2008 Share Posted November 29, 2008 Tv-ul avea child lock activat si proprietarul nu reusea sa porneasca tv-ul!Telecomanda era defecta si nu lua tasta 2!Dupa ce am curatat-o am reusit sa dezactivez child lock.Tv-ul functiona normal!Am scos memoria 24c08 pt.a o copia si STUPOARE-dupa ce am pus-o la loc led-ul de standby clipeste regulat si tv-ul nu porneste!(traseele memoriei sint bune).AJUTOR(macar cu un dump pt. acest tv)!Multumesc! Quote Link to comment Share on other sites More sharing options...
spyry Posted November 29, 2008 Share Posted November 29, 2008 Icearca cu alta memorie si vezi ce se inimpla! Quote Link to comment Share on other sites More sharing options...
TOMITA Posted November 29, 2008 Author Share Posted November 29, 2008 Am utilizat 3 noi dump-uri fara succes!Asta este cauza pentru care sint blocat! Quote Link to comment Share on other sites More sharing options...
gabiTV Posted November 29, 2008 Share Posted November 29, 2008 Ce terminatie are procesorul? Quote Link to comment Share on other sites More sharing options...
TOMITA Posted November 29, 2008 Author Share Posted November 29, 2008 MIF Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted November 30, 2008 Share Posted November 30, 2008 Ai facut si ce scrie aici? http://forum.microprocesoare.ro/index.p ... 96#msg4996 Incearca si cu asta. Quote Link to comment Share on other sites More sharing options...
TOMITA Posted November 30, 2008 Author Share Posted November 30, 2008 Ai facut si ce scrie aici? http://forum.microprocesoare.ro/index.p ... 96#msg4996Incearca si cu asta.Multumesc frumos!Functioneaza cu ce mi-ati propus dar scris pe alt 24c08.Probabil ci-ul tv-ului a patit ceva cu toate ca pony prog nu da eroare la scriere. Quote Link to comment Share on other sites More sharing options...
Join the conversation
