spyry Posted November 29, 2008 Share Posted November 29, 2008 Am un tv Daewoo model-K20C4T,care nu simte nimic de la telecomanda mentionez ca inainte de avea acest defect in tv am inlocuit memoria 24c08 deoarece nu simtea nici din tastele de pe panoul frontal ,dupa inlocuirea memoriei tv-ul functioneaza dar nu mai vrea din telecomanda,culmea ca pe alt tv de acelasi tip telecomanda functioneaza perfect. VA ROG AJUTATI-MA CU CEVA IDEI !!!! Quote Link to comment Share on other sites More sharing options...
Stefan Posted November 29, 2008 Share Posted November 29, 2008 ai verificat receptorul IR?defectarea (sau alterarea softului) memorie din ce cauza se datoreaza ? daca problema a apraut in urma descarcarilor electrice, cauta un procesor de schimb. Quote Link to comment Share on other sites More sharing options...
spyry Posted November 29, 2008 Author Share Posted November 29, 2008 Multumesc Stefan!dar procesorul este un {smd }DW195C DE5 ,si chiar de as avea procul nu am scule adcvate pentru al putea inlocui ,si in ce priveste descarcarile atmosferice nu cred ca e cazul pentru ca tv-ul sa defectat acum 3 zile . Quote Link to comment Share on other sites More sharing options...
TOMITA Posted November 29, 2008 Share Posted November 29, 2008 Cred ca singura problema este memoria! Quote Link to comment Share on other sites More sharing options...
spyry Posted November 29, 2008 Author Share Posted November 29, 2008 POT INLOCUI MEMORIA CU UNA DE ACELASI TIP DINTR-UN PROVISION? Quote Link to comment Share on other sites More sharing options...
spyry Posted November 29, 2008 Author Share Posted November 29, 2008 Tomita esti tare frate ,ai avut dreptate ,am inlocuit memoria de la un Provision si functioneaza perfect MULTUMESC ! Quote Link to comment Share on other sites More sharing options...
Join the conversation
