CRISTIANTV Posted November 28, 2008 Share Posted November 28, 2008 VA SALUT. SUNT NOU PE FORUM NU STIU PREA BINE UNDE SA POSTEZ.AM O RUGAMINTE MA POATE AJUTA CINEVA CU UN DUMP DE MEMORIE PTR. UN TV KENSTAR CTV 20C01CARE ARE PROC. ST92195C7B1/MTO. MULTUMESC MULT. Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 28, 2008 Share Posted November 28, 2008 http://forum.microprocesoare.ro/index.php?topic=1003.0 Quote Link to comment Share on other sites More sharing options...
CRISTIANTV Posted November 28, 2008 Author Share Posted November 28, 2008 MULTUMESC TV1 DAR NU AM ACCES PE FORUMUL LOR. DACA MA POATE AJUTA CINEVA CU UN ATASHAMENT ? Quote Link to comment Share on other sites More sharing options...
zvasile Posted November 29, 2008 Share Posted November 29, 2008 VA SALUT. SUNT NOU PE FORUM NU STIU PREA BINE UNDE SA POSTEZ.AM O RUGAMINTE MA POATE AJUTA CINEVA CU UN DUMP DE MEMORIE PTR. UN TV KENSTAR CTV 20C01CARE ARE PROC. ST92195C7B1/MTO. MULTUMESC MULT. Quote Link to comment Share on other sites More sharing options...
CRISTIANTV Posted November 29, 2008 Author Share Posted November 29, 2008 ZVASILE MUILTUMESC PTR AJUTOR AM REZOLVAT PARTIAL . CU DUMPUL TAU TV-ULPRINDE TOATE POSTURILE SI LE MEMOREZA DAR NU AU SUNET. NORMA ESTESETAta CORECT PE BG TOTUSI NU AM SUNET. AM INCERCAT CU ALT DUMP LUAT DE PE UN SITE RUSESC DAR CU ASTA AM SUNET IN SCHIMB IMAGINEA ESTE MICA PE VERTICALA SI CULMEA NU MAI ACTIONEAZA NICI TELECOMANDA .CARE SA FIE EXPLICATIA???? Quote Link to comment Share on other sites More sharing options...
zvasile Posted November 29, 2008 Share Posted November 29, 2008 ZVASILE MUILTUMESC PTR AJUTOR AM REZOLVAT PARTIAL . CU DUMPUL TAU TV-ULPRINDE TOATE POSTURILE SI LE MEMOREZA DAR NU AU SUNET. NORMA ESTESETAta CORECT PE BG TOTUSI NU AM SUNET. AM INCERCAT CU ALT DUMP LUAT DE PE UN SITE RUSESC DAR CU ASTA AM SUNET IN SCHIMB IMAGINEA ESTE MICA PE VERTICALA SI CULMEA NU MAI ACTIONEAZA NICI TELECOMANDA .CARE SA FIE EXPLICATIA????ce sasiu are televizorul?cu ala care nu ai sunet,se schimba BG/DK? Quote Link to comment Share on other sites More sharing options...
CRISTIANTV Posted November 29, 2008 Author Share Posted November 29, 2008 IN MENIU SCHIMBA TOATE NORMELE TOTUSI NU E SUNET. CU CELALALTDUMP DE CE AM POATE ESTE NEVOIE SA INTRUIN SERVICE DAR NU AM IDEE CUM .SASIUL E CEVA CHINEZESC FACUT PTR THOMSON PE O ETICHETA LIPITA PE PLACA SCRIE:CTV20C21 ;TD195-20 ;THOMSON LINE D ;WUJIANG.STIE CINEVA CUM SE INTRA IN SERVICE LA ACEST TV Quote Link to comment Share on other sites More sharing options...
gabiTV Posted December 1, 2008 Share Posted December 1, 2008 "MENU"-- "6" ? "4" ? "8" ? "3" Quote Link to comment Share on other sites More sharing options...
CRISTIANTV Posted December 1, 2008 Author Share Posted December 1, 2008 THANKS. GABITV Quote Link to comment Share on other sites More sharing options...
Join the conversation
