paun nelu Posted November 24, 2008 Share Posted November 24, 2008 am un tv platinium cu trafo ars si nu gasesc echivalenta hr, trafo are urmatoarele date:MF-6695AMTI-LTC-020RU E58491/0307Z1BTelevizorul este:Platinium RML-20-OTXT , J= TDA 9361PS/N2/310999,daca detineti o schema pt el ar fi de ajutor pt.o eventuala modificare in caz ca nu gasesc trafo.multumesc anticipat! Quote Link to comment Share on other sites More sharing options...
cristronic Posted November 24, 2008 Share Posted November 24, 2008 Am un traf nou,disponibil.Mai multe detalii,pe PM. Quote Link to comment Share on other sites More sharing options...
costei Posted November 24, 2008 Share Posted November 24, 2008 cred ca asta este Quote Link to comment Share on other sites More sharing options...
paun nelu Posted November 24, 2008 Author Share Posted November 24, 2008 Multumesc costei pt. intentie dar nu este aceea schema.daca nu voi reusii sa-l izolez voi intreba clientul si voi lua legatura cu tine cristronic. Quote Link to comment Share on other sites More sharing options...
Join the conversation
