son Posted November 21, 2008 Share Posted November 21, 2008 Buna ziua. Am o problema si sper ca pot fi ajutat.Mi sa ars acest trafo si nu scrie pe el decat 3c58 sub el pe miezul de ferita.Mi sa indicat HR7323 SI HR7325 ,ele sar potrivi dar nu stiu care ar fi exact si nu as vrea sa dau banii pe el si sa nu mearga.Sper sa pot fi ajutat cu o idee salvatoare.Multumesc anticipat. Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 21, 2008 Share Posted November 21, 2008 Asta e cel corect: http://www.hrdiemen.es/products/index.p ... HR7325.gif Quote Link to comment Share on other sites More sharing options...
son Posted November 21, 2008 Author Share Posted November 21, 2008 Ok se pare ca acesta ar fi cel bun(HR7325) si o sa-l cumpar .Multumesc acelora care au incercat sa ma ajute . pe curand Quote Link to comment Share on other sites More sharing options...
JAD Posted November 21, 2008 Share Posted November 21, 2008 In Depanatorul nr.13 la pag.16 este un articol privind CAUZELE defectarii trafului de linii la Waltham-Videoton. Obligatoriu de citit si de facut verificarile imediat dupa montarea noului traf. Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 21, 2008 Share Posted November 21, 2008 Ia si schema ca poate ai nevoie... Quote Link to comment Share on other sites More sharing options...
son Posted November 23, 2008 Author Share Posted November 23, 2008 Ia si schema ca poate ai nevoie...Ok .multumesc f.mult pentru schema sper sa ma descurc in continuare. Quote Link to comment Share on other sites More sharing options...
kostel Posted November 24, 2008 Share Posted November 24, 2008 Cred ca am eu asa cevaDca te intereseaza astept un raspuns si il caut Quote Link to comment Share on other sites More sharing options...
Join the conversation
