Guest batunga Posted November 20, 2008 Share Posted November 20, 2008 Am tv-ul asta de 6 ani si de 2 saptamani tot imi dispare si apare sunetul.S-ar putea sa fie o lipitura rece....Daca are cineva schema m-ar ajuta foarte mult.... Quote Link to comment Share on other sites More sharing options...
maresmircea57 Posted November 20, 2008 Share Posted November 20, 2008 Citeste aici viewtopic.php?f=17&t=12666 Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 21, 2008 Share Posted November 21, 2008 Tevion MD7115VTS-S chassis TV17XL.6 Quote Link to comment Share on other sites More sharing options...
Guest bubu27 Posted May 2, 2011 Share Posted May 2, 2011 buna am tv tevion md 7115A, 100hz problema e ca am incarcat mai multe tranz. final bu 508,bu 808, c2527 originalul c5129 si il buseste,am pus un 2525 pornesc merge 1 minut si gata il arde ,ce poate fi ce imi recomandati,am citit pe forum de un tranz,c5552 dar la magazine nu gasesc,nici la depozite Quote Link to comment Share on other sites More sharing options...
dan cod Posted May 2, 2011 Share Posted May 2, 2011 buna am tv tevion md 7115A, 100hz problema e ca am incarcat mai multe tranz. final bu 508,bu 808, c2527 originalul c5129 si il buseste,am pus un 2525 pornesc merge 1 minut si gata il arde ,ce poate fi ce imi recomandati,am citit pe forum de un tranz,c5552 dar la magazine nu gasesc,nici la depoziteEu in TVurile astea pun C5588si merg super nu se incalzesc prea tare.E clar ca BU508 nu are cum sa mearga acolo.Cuza defectarii e rezolvata(in general conatcte in zona driver,EW,chiar condul de recuperare)?Daca cauza nu e rezolvata nu tine nici un tranzistor acolo asta e clar. Quote Link to comment Share on other sites More sharing options...
leoncris Posted May 2, 2011 Share Posted May 2, 2011 viewtopic.php?f=17&t=11486&p=602242&hilit=chassis+TV17XL.6#p602242 Quote Link to comment Share on other sites More sharing options...
Guest bubu27 Posted May 2, 2011 Share Posted May 2, 2011 buna am tv tevion md 7115A, 100hz problema e ca am incarcat mai multe tranz. final bu 508,bu 808, c2527 originalul c5129 si il buseste,am pus un 2525 pornesc merge 1 minut si gata il arde ,ce poate fi ce imi recomandati,am citit pe forum de un tranz,c5552 dar la magazine nu gasesc,nici la depozitesi inca ceva pornesc de la buton pornire ,nu intra in stand by il las asa si automat dupa 20 min intra singur in stand by cauza ce poate fi uncondensator nu se incarca cum trebe sau ic tda 16846?? Quote Link to comment Share on other sites More sharing options...
dan cod Posted May 2, 2011 Share Posted May 2, 2011 Pai acolo nici sursa de alimentare nu este ok.Cam greu asa de reparat un TV.Reparati sursa si cand va porni bine treceti la finalul linii?U1 cat este? Quote Link to comment Share on other sites More sharing options...
Guest bubu27 Posted May 2, 2011 Share Posted May 2, 2011 Pai acolo nici sursa de alimentare nu este ok.Cam greu asa de reparat un TV.Reparati sursa si cand va porni bine treceti la finalul linii?U1 cat este?u1-145v Quote Link to comment Share on other sites More sharing options...
Guest bubu27 Posted May 2, 2011 Share Posted May 2, 2011 Eu in TVurile astea pun C5588si merg super nu se incalzesc prea tare.E clar ca BU508 nu are cum sa mearga acolo.Cuza defectarii e rezolvata(in general conatcte in zona driver,EW,chiar condul de recuperare)?Daca cauza nu e rezolvata nu tine nici un tranzistor acolo asta e clar.C5588 nu prea gasesc online in magazine si depozite Quote Link to comment Share on other sites More sharing options...
naetv Posted May 3, 2011 Share Posted May 3, 2011 C5588 nu prea gasesc online in magazine si depoziteVezi mp - aici nu se poate , este considerata reclama Quote Link to comment Share on other sites More sharing options...
Join the conversation
