codrin Posted November 18, 2008 Share Posted November 18, 2008 am nevoie de un dump ptr acest sasiu chinezescprocesorul este LC863340A/5Y48/1GD0jungla LA76810Aam incercat cateva dumpuri de pe net insa defectul persista.le-am incercat pe acesteaviewtopic.php?f=17&t=33550&start=0&st=0&sk=t&sd=acauta canalele dar fara a prinde ceva.daca aveti si schema acestui sasiu ar fi f. bine. Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 18, 2008 Share Posted November 18, 2008 http://www.e-rusu.ro/dump/1%20Tv/Hisense/ http://www.e-rusu.ro/scheme/Hisense/TV% ... 20LA76810/ Quote Link to comment Share on other sites More sharing options...
codrin Posted November 19, 2008 Author Share Posted November 19, 2008 incercasem cu dumpul de la www.e-rusu.ro cu acesta tv-ul nu porneste...??? iar schema indicata nu este a sasiului TC2199T(difera partea de procesare) procesorul LC863348 are pinii configurati diferit fata de LC863340A HISENSE TC2199T se aseamana foarte mult cu sasiul SKYWORTH 3Y01 - LA8633XX,LA76810 multumesc , totusi, pentru indicatii. Quote Link to comment Share on other sites More sharing options...
bigbrother Posted February 14, 2010 Share Posted February 14, 2010 Salut d-le Codrin, intamplator am un tv identic cu al dv. cu aceeasi defectiune, are imagine buna pe av, dar pe cablu cauta dar nu prinde nici un program.Am reusit so agat un program dar se vede o imagine stramba cu interferente.Ati reusit sa-l faceti? va mai aduceti aminte de unde provenea defectiunea?Multumesc, Quote Link to comment Share on other sites More sharing options...
dumi_bv Posted February 15, 2010 Share Posted February 15, 2010 Daca deschizi telecomanda, are in stanga jos, un buton de service, acoperit.OPT. 03 RF AGC. ENGINEER 0 se face 1 ptr. a avea acces la toate optiunile din service menu. Quote Link to comment Share on other sites More sharing options...
bigbrother Posted February 22, 2010 Share Posted February 22, 2010 Sal, dumi_bv, multumesc pentru sfat si intarziere, dar am intrat in meniu service cu tastele: meniu apasat de 2 ori, view si mute, iar paginile se schimba cu tasta clock, iar defectiunea am rezolvat-o prin schimbarea lui LA76810 pentru ca pe cel vechi nu aveam tensiunea de 2,5V la pin 47 si am reglat din nou L203 pana am reusit sa am culoare pe toate programele, pentru ca la noul integrat nu aveam culoare la programele mai slabe.O zi buna va doresc. Quote Link to comment Share on other sites More sharing options...
ROBEERT Posted February 22, 2010 Share Posted February 22, 2010 am nevoie de un dump ptr acest sasiu chinezescprocesorul este LC863340A/5Y48/1GD0jungla LA76810Aam incercat cateva dumpuri de pe net insa defectul persista.le-am incercat pe acesteaviewtopic.php?f=17&t=33550&start=0&st=0&sk=t&sd=acauta canalele dar fara a prinde ceva.daca aveti si schema acestui sasiu ar fi f. bine.Poftim stimate coleg. Am doua salvari. Poate, poate.Succes. Quote Link to comment Share on other sites More sharing options...
Join the conversation
