spyry Posted November 17, 2008 Share Posted November 17, 2008 Salutare MESERIASI!Ma poate ajuta cineva, cum pot intr in meniul service la acest TV Chinezarie ,mentionez ca a fost trasnit si sa dus procesorul ,pe care l-am inlocuit si acum are sunet dar nu are imagine apare ca un fel de curcubeu ceva de genul imagine fara focalizare .,dare cu totul altceva,daca ati mai inilnit asa ceva ,va rog ajutati-ma si pe mine! Quote Link to comment Share on other sites More sharing options...
naetv Posted November 17, 2008 Share Posted November 17, 2008 eu cred ca tubul este magnetizat-ai totusi imagine daca umbli la focus, se vede ceva? Quote Link to comment Share on other sites More sharing options...
spyry Posted November 17, 2008 Author Share Posted November 17, 2008 Se focalizeaza doar acel curcubeu de care v-am zis mai devreme dar imagine nu exista. Quote Link to comment Share on other sites More sharing options...
cristronic Posted November 17, 2008 Share Posted November 17, 2008 Posibil spotul deplasat pe verticala.Tensiuni de alimentare baleiaj vertical incorecte sau comandat prost de jungla. Quote Link to comment Share on other sites More sharing options...
spyry Posted November 17, 2008 Author Share Posted November 17, 2008 Baleajul vertical OK toate tensiunile ,cred ca aveti dreptate defectul pare sa fie din JUNGLA ,SI CUM JUNGLA E {DEASA} CRED CA M-AM BLOCAT .ROG daca aveti o schema si ceva detalii ,ajutatima! Quote Link to comment Share on other sites More sharing options...
naetv Posted November 17, 2008 Share Posted November 17, 2008 Ce intagrate are pe placa ? Ce jungla ce procesor? Quote Link to comment Share on other sites More sharing options...
tv1 Posted November 17, 2008 Share Posted November 17, 2008 sasiu TV2K Quote Link to comment Share on other sites More sharing options...
spyry Posted November 17, 2008 Author Share Posted November 17, 2008 TDA9351PS/N3 ;24Cmemorie;STV9302 BV;UC3842 SURSA;TDA7856 SUNET; SASIU 40-MNTV2KR-L4T. Quote Link to comment Share on other sites More sharing options...
naetv Posted November 17, 2008 Share Posted November 17, 2008 atunci asta Quote Link to comment Share on other sites More sharing options...
Guest GicuRebenciuc Posted April 23, 2012 Share Posted April 23, 2012 de ce oare nu pot sa vad (si sa descarc !) pdf-ul ????? Mai exista? L-a sters cineva??? Quote Link to comment Share on other sites More sharing options...
kostel Posted April 23, 2012 Share Posted April 23, 2012 Dra cand ai sunet si misca petele acelea de culoare ca si cum ai avea imagine?Dca se misca acele pete,schimba soclul TKSigur este corodat Quote Link to comment Share on other sites More sharing options...
Toni Marginean Posted April 23, 2012 Share Posted April 23, 2012 de ce oare nu pot sa vad (si sa descarc !) pdf-ul ????? Mai exista? L-a sters cineva???Au fost sterse in 2010 dar daca aveti nevoie de schema dati cautare pe forum si o sa o gasiti in alta postare. Quote Link to comment Share on other sites More sharing options...
leoncris Posted April 23, 2012 Share Posted April 23, 2012 de ce oare nu pot sa vad (si sa descarc !) pdf-ul ????? Mai exista? L-a sters cineva??? http://www.eserviceinfo.com/downloadsm/ ... s%29_.html Quote Link to comment Share on other sites More sharing options...
FLORIN IORDACHE Posted April 23, 2012 Share Posted April 23, 2012 Hristos a inviat !! Daca dadeati o mica cautare pe acest forum,cu cea mai mare siguranta gaseati schema la acest tv,de exemplu aici : viewtopic.php?t=92435&p=828187#p828187 . Mult Succes pe viitor !!! Quote Link to comment Share on other sites More sharing options...
Guest GicuRebenciuc Posted April 24, 2012 Share Posted April 24, 2012 Hristos a inviat !! Daca dadeati o mica cautare pe acest forum,cu cea mai mare siguranta gaseati schema la acest tv,de exemplu aici : viewtopic.php?t=92435&p=828187#p828187 . Mult Succes pe viitor !!!Multumesc tuturor pt. un sfat care m-a ajutat! Pot sa explic: am cautat pe „goagal” modelul de sasiu ce ma interesa si m-a trimis la prima postare de pe forum. Aici nu am gasit fisierul(asa cum ma asteptam!), de aceea am pus intrebarea, fara sa mai incerc si o cautare pe forum. SCUZE TUTUROR celor care si-au pierdut timpul dandu-mi raspunsuri !!! Quote Link to comment Share on other sites More sharing options...
Join the conversation
