spyry Posted November 17, 2008 Share Posted November 17, 2008 Salutare! Am si eu o problema cu un TV Daytron DCS 2043VR ,am gasit sursa in scurt am inlocuit-o dupa aceea am depistat si finalul de linii in scurt {D1555} si l-am inlocuit cu un BU 808DFI,a pornit dar cu dimensiune redusa pe orizontala si BU 808 SE INCALZESTE PUTERNIC,oare acesta sa nu fie compatibil sau exista alta problema!? Quote Link to comment Share on other sites More sharing options...
Mihai85 Posted November 17, 2008 Share Posted November 17, 2008 bu808 este darlington iar D1555 este normal. mai bine puneai bu508 Quote Link to comment Share on other sites More sharing options...
spyry Posted November 17, 2008 Author Share Posted November 17, 2008 Am pus si BU508 si face la fel! Quote Link to comment Share on other sites More sharing options...
spyry Posted November 17, 2008 Author Share Posted November 17, 2008 Am rezolva problema defectul era in bobina de deflexie orizontala si functioneaza si cu BU808. ORICUM MULTUMESC PENTRU AJUTOR!. Quote Link to comment Share on other sites More sharing options...
Join the conversation
